I made a stupid mistake of not checking my pockets. Yep, my memory card went through the washing machine and the dryer. Its done. Where can I get another one?
You "should" be able to get one from Honda. You'll need the part number (from the Online Parts Manual) and PIN number off the PGM (little silver sticker behind the instrument panel).
If Honda won't talk to you, then you may need to go the HRC card route. You'll still need the PIN number off the PGM, but you will need an HRC seller to get the card for you. _________________ Andy.
As Andy said, use the part number and PIN, but my understanding was that Honda no longer supply the std cards.....the HRC 030 card is the only way to go. Might be wrong of course...
I've found Tyga Performance.com to be the cheapest route for the HRC card, takes about a month for them to get it to you. Once you get your card you'll need to spice the wiring loom, again Tyga's site shows how to do this. Make sure when you first insert the HRC card you leave it in the slot untill you see the large temp guage. I think it says 'SP' when you first put in a new card, but it'll disappear after 30-40seconds. If you do take the card out while it's going through the process, I think it ruins the card. Now someone told me this a long time ago and i'm not too sure if it's true.......but why risk it.
Good luck with getting a std card, and let me know how you get on.......I'm interested to know if they are still avaliable.
No, I think people just overlook the fact that the Forum IS NOT the Site, and the Forum wouldn't even exist without it!
It is also very irritating when information is available on the Site and yet people still ask on the Forum... especially when the info is blatant! _________________ Andy.
