Fork Swap
montsta56
Fork Swap
Thu Nov 01, 2007 9:32 pm » Post: #1 » Download Post
Hi guy's will NC30 fork's/ Front end bolt right on to a mc21??? Is the steering stem length the same an also is the thread the same ... cheers
Thu Nov 01, 2007 10:33 pm » Post: #2 » Download Post
No, no, and... no!
Use the MC21 triples and use the VFR forks, disks and fender. Either NSR or VFR calipers should both be OK.
Can't tell you about the wheel, as I am unsure of the spacers you'd use. I wouldn't want to run the wider VFR wheel without the F3 suspension though, as it doesn't seem to work without HRC geometry (for me anyway).
rgvkiwi
Fri Nov 02, 2007 12:01 am » Post: #3 » Download Post
Hi Guys
Just interested, is there much difference or improvement to be had in doing this.
I thought being of the same vintage would be the same or similar parts...?
Mark
Fri Nov 02, 2007 9:40 am » Post: #4 » Download Post
Maybe, if you have an "R" model or buggered forks! You'll also end up with 296mm discs instead of 276mm.
VFR forks are set up for a much heavier bike, but then again, most of us are much heavier riders than the average Japanese owner.
All common sense stuff really. Why not be a bit daring and try it, and then tell everyone what you think?!
Luke F
Sat Nov 03, 2007 8:29 am » Post: #5 » Download Post
When looking into this also check the VFR vs NSR total fork length, I think, maybe the VFR legs are a we bit shorter as well.
Farting is funny
rgvkiwi
Mon Nov 05, 2007 9:14 am » Post: #6 » Download Post
Ouch, that would make for a pretty sharp steering motorcycle!
Mark
Mon Nov 05, 2007 12:38 pm » Post: #7 » Download Post
Sharp is my old front-end! 1991 RWU HRC RS250. I can't remember the length of them off-hand, but it was seriously aggressive... superb though! The gap between the front fender and the nose fairing was only about 70mm!
It scrubbed the hell out of front tyres, but was planted.
beakergixer750cc
Mon Nov 05, 2007 8:23 pm » Post: #8 » Download Post
as you can see nc 30 front end including wheel works well on my mc16,using mc16 steerer welded onto nc30 bottom yoke,lock stops have basically the same spacing as the mc16 so no problems there for me.
