in normal riding everything is fine, but when i ride agressively lets say almost redline in each gears, rpms is too high each time i pull the clutch but throttle is in close position i have to downshift and make engine breaks in each gear for the rpm to settle in 1200. scenario= 10K rpm on 5th gear going to a stop leaving it on 5th gear pull the clutch rpm does not go down.
You dont earn respect in one day, you earn it day by day
