reed valves?
k3
    Send private message View user's profile Visit poster's website Yahoo Messenger
reed valves?
Mon Nov 12, 2007 3:02 am » Post: #1 » Download Post
im just wondering what is/are the problem/s.
in normal riding everything is fine, but when i ride agressively lets say almost redline in each gears, rpms is too high each time i pull the clutch but throttle is in close position i have to downshift and make engine breaks in each gear for the rpm to settle in 1200. scenario= 10K rpm on 5th gear going to a stop leaving it on 5th gear pull the clutch rpm does not go down.
Embarassed help Embarassed
You dont earn respect in one day, you earn it day by day
alannsr250
    Send private message View user's profile Send e-mail Visit poster's website MSN Messenger
Mon Nov 12, 2007 9:30 am » Post: #2 » Download Post
sounds like a carberation problem maybe or the cable or slide sticking in the carb, anything along thos elines i would think
Honda nc23 CBR400 AERO 1986, 1990 honda NC23 Tri-Arm, 1987VFR400 NC24 Rothmans Rep, NSR250 MC16 1987, CL250s 1983. Moto guzzi zigolo 110cc 1958. Fantic 50cc 1972. Suzuki Cobra Race bike 500cc 2t 1975 , GP125 1975. Triumph T110 1954. BSA Thunderbird 1955. Ariel VB 600 1952, 1990 MuZ 125 etz.
p0lariso
Mon Nov 12, 2007 2:29 pm » Post: #3 » Download Post
Ya sounds carb related.. sticky throttle or choke ?
1996 MC28 SE
NSR250R2R
k3
Tue Nov 13, 2007 1:35 am » Post: #4 » Download Post
oh i forgot to mention that my rc valves are set full open because of a busted servo motor. guys do you think thats the cause? im not sure if its a carb problem while park in neutral the problem is not present it revs and idle smoothly thats why im trying to disregard a carb problem. more help pls.
alannsr250
Tue Nov 13, 2007 11:12 am » Post: #5 » Download Post
still sounds like the carbs the valves wouldnt effect it. possible theres a air leak somwhere in your engine causing it to run like that i have had the same problem and was due to a crack in my crankcases that only seamed to let air in at full revs
k3
Wed Nov 14, 2007 2:37 am » Post: #6 » Download Post
thanks alan ill check the carbs but i hope its not a crack on my engine Crying or Very sad
or maybe its the rubber intake manifold.
alannsr250
Wed Nov 14, 2007 4:25 am » Post: #7 » Download Post
its probly not just something it could be theres alot of areas on a two stroke to cause problems with idle speed and running lean and once i check the carb is not the problem on my bike its usualy air leaking through a crank seal, crack in a case, worn rubbers, holes in the exhaust, ignition timing, rust in the cables, frayed cables, oil pump cable sticking ..................
k3
Wed Nov 14, 2007 10:03 am » Post: #8 » Download Post
thank you so much alan youre a big help. its going to be a very busy weekend for me Laughing
