Error 3 on MC28 display
Fallen
Guest
Wed Feb 25, 2004 10:16 am » Post: #1 » Download Post
Can anyone explain the error? and how to rectify it?
butch
Guest
Sun Mar 07, 2004 9:06 pm » Post: #2 » Download Post
throtle position sensor on carbs not conected or sensor playing up
RZRob1
    Send private message View user's profile AIM Address
TPS
Fri Sep 18, 2009 4:52 am » Post: #3 » Download Post
Hello, Newbie Here. Just got a slightly rough '96 MC28. Bike seems to run okay, but Error 3 flashes on the dash (regardless of revs or whether Run switch is On or Off) and red warning light directly below remains on constantly.
Could these 2 messages be related?
I've done a search and saw adjustment of TPS may be necessary, but other posts suggest that message may go off at different RPMs. Considering mine's on all the time (and plugged in) should I just not "over think it" and buy a new TPS?
Anyone got an idea of the cost and best source? I'm a Ti member. It seemed like a good idea considering I'm green and the bike needs help.
Thanks in advance folks.
RZ Rob
Fri Sep 18, 2009 11:53 pm » Post: #4 » Download Post
Hello Rob, and welcome to the Forum.
Have a look at this thread:
http://www.nsr250.net/forums/viewtopic.php?t=3978&highlight=err3
The PGM-IV errors are more often reported as Err1, Err2, Err3 etc., so that probably produced a better result that you found with your search.
RZRob1
Still Looking
Sun Sep 20, 2009 5:48 am » Post: #5 » Download Post
Thanks Andy,
That link didn't really get me anywhere. But I did some different searches. I probably just need to get in and study the problem (ERR3 Flashing). From what I've read, it's TPS, but if it goes away at different revs it can be adjusted out. Because mine's on constantly (and plugged-in) I'm suspecting the TPS may be bad. I'm going to have a look and maybe remove it and check the resistance.
Mostly I was looking for insight from others' experiences. Anyone want to share?
RZ Rob
Keep the Rubber Side Down
apexxn
Sun Sep 20, 2009 9:39 pm » Post: #6 » Download Post
The easiest thing would be to plug in another set of carbs just to make sure your tps is the culprit.
Ummm where could you get a spare set of carbs to test with????
RZRob1
Checking the TPS
Mon Sep 21, 2009 4:36 pm » Post: #7 » Download Post
Thanks Mike,
Before I go that far, I'm going to have a look at the TPS myself just to gain a better understanding of how it works. I'm picturing if I remove it I'll see that it's some type of variable resister (rheostat or potentiometer). My assumption is that either opening or perhaps closing the circuit all together will make the message go away.
If that doesn't get me anywhere, I may ask you to bring your thinking cap or spare parts over if we happen to meet up to go to the Two Stroke Extravaganza.
Rob
