  • NSR250 Forums Index ‹ NSR300R Discussion
NSR300 track day = ENGINE DEATH! :(
rodney007
Fri Feb 22, 2008 5:43 am » Post: #1 » Download Post
yep first track day after freash rebuild and mint tuneup
3 laps in coming from top of 6th gear (at 12000 rpm)
down to second gear into hair pain,, just coming out noticed
a rattling sound then i started to pull over, the power died and when the bike stope'd the rpm died out, i try to kickstart but the leaver wouldnt move, so i assumed (in a gutted state) that it seized..
took bike back to work and droped the bottom cylnder , luckily there was no damage to cylnder sleeve and there was oil also in the mix,
although when looking in the head TWO BRASS PIECES came out along with
shards of metal, the piston is also damage around the edge but rings seem okay, also there was a E-CLIP in the head also,
the connecting-rod has no play (foward backward) but does have play to the right side as it looks like a spacer thingy is missing beside the con-rod
im guessing its the thrust bearing washer?? cause my mechanic said that thats the only thing coper or brass looking in the engine
NOOOOOooooooo! after about 3-4 thousand bucks this happens on my third lap at the track@!.
anyone know wat i should do, iwhere i should look,
im really screwed guys. any help much appreciated.
RVT2002
Fri Feb 22, 2008 6:26 am » Post: #2 » Download Post
Looks like your crank is done. I guess im a lil bit ok than you as i was on my 2nd session when my crank blew up Laughing
rodney007
Fri Feb 22, 2008 9:24 am » Post: #3 » Download Post
yeh, gutted man, oh well im due for full licence in 2-3 weeks so looks like i might graba '08 or something, just so i know something aint gunna blow up *touch wood*
could sell it as a 300 kit needing pistons and rings * are cheap *
with only 2500kms on mint as cylnder heads it will cost half the price as new to get a 300 kit
zxcvbnm
Sat Feb 23, 2008 6:04 am » Post: #4 » Download Post
That sucks. Any chance of some pic's of the damage and the bits specially the E-clip.
jeff350lc
Sat Feb 23, 2008 11:51 am » Post: #5 » Download Post
NSR Wayne had the same problem on his 18, a thrust washer broke up and the broken bits got dragged up on top of the piston.
Not good news, i'm gutted for you Crying or Very sad
banshee
1996 Honda NSR250MC28SE
Sat Feb 23, 2008 3:49 pm » Post: #6 » Download Post
CRASH, BANG, WALLET!!!!!!!!!!!!!!!
jkolewski
Sat Feb 23, 2008 4:21 pm » Post: #7 » Download Post
That SUCKS. What was the outside temp? I had a similar insident only mine happen in sixth and locked the rear wheel. Evil or Very Mad Mine was a jetting mistake Embarassed and I got away with a hone and piston. You can't run it without a thrust washer though.
1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
Sun Feb 24, 2008 12:02 am » Post: #8 » Download Post
I feel for you.
Have you beaten it with a stick yet?
Sun Feb 24, 2008 3:08 am » Post: #9 » Download Post
StephenRC45 wrote:I feel for you.
You been watching Fawlty Towers again Steve?
rodney007
Sun Feb 24, 2008 11:12 am » Post: #10 » Download Post
meh its okay,. my fault running a new top end on a 55k bottom end Very Happy
well the 3 laps i got in i gave it heaps,
guna get a 08 600rr
Sun Feb 24, 2008 3:51 pm » Post: #11 » Download Post
rodney007 wrote:guna get a 08 600rr
I'd rather break my legs again.
rodney007
Sun Mar 02, 2008 10:02 am » Post: #12 » Download Post
its okay.
i have k4 gsxr600 now Very Happy
wb
Sun Mar 02, 2008 11:42 am » Post: #13 » Download Post
My sincerest comiserations... Wink
It would perhaps have been wise to have had the crank rebuilt and balanced etc. before pushing more power through it. Cranks are a service item, they don;t just spin forever without attention.
I reckon you should fix up the NSR. Do it properly and it'd give you far more fun and satisfaction than the Gixer ever will. The occasional engine blow up is inevitable (on any bike) if you push them a bit. Fixing them up better than before is an important part of the fun and satisfaction in my book.
Wb
zxcvbnm
Sun Mar 02, 2008 12:45 pm » Post: #14 » Download Post
What are you going to do with your NSR now.
rodney007
Mon Mar 17, 2008 4:22 am » Post: #15 » Download Post
fixing it, should be up and running in week or so Very Happy
thanks guys
