Are these HRC parts?
Moriwaki-man
Thu Mar 06, 2008 7:28 am » Post: #1 » Download Post
What you think? Is it a bit of sales patter or are these HRC
Carb's
Described as being set up and using HRC needles and jets and comes with a range of jets and needles too - any way of actually knowing? Somebody using OKshon is bidding on them Rolling Eyes
USD front end from a HRC RS250 which has been retro-fitted onto an NSR250. Top bridge is HRC RS250 and they recomend using a MC21 locking cyclinder with it. Wheel is also HRC Magtek for RS250, in good order and serviceable.
Here is the matching rear;
Resistance is futile!
chappyr1
Thu Mar 06, 2008 8:56 am » Post: #2 » Download Post
If only I lived in Japan Sad
cgallant
2001 Honda RS250
Thu Mar 06, 2008 12:25 pm » Post: #3 » Download Post
not sure about the carbs. However the forks are odd? Never seen that box at the bottom of the forks? I know my 01 RS250 forks have an adjuster there, but nothing like a large box like the ones in the pics? Also, the top fork clamp would be questionable to me. HRC never put an ignition lock/tumbler on the RS so not sure why there would be a place to put one on these?
The swing arm looks NSR, as the RS was a right side drive. The swing arm in your picture is a left side drive.
Charles Gallant
cgallant
2001 Honda RS250
Thu Mar 06, 2008 12:29 pm » Post: #4 » Download Post
okay, on the forks, after a close look, the box thing at the bottom may be a metal bracket that is attached to where the fender/mud guard attaches to. However the front calipers don't look like the RS calipers.
Charles Gallant
Moriwaki-man
Thu Mar 06, 2008 3:04 pm » Post: #5 » Download Post
The rear end is NSR with a RS Magtek on it.
The boxes on the forks had me wondering Confused
cgallant
2001 Honda RS250
Thu Mar 06, 2008 3:13 pm » Post: #6 » Download Post
the boxes actually just look like brackets and nothing more (but I could be wrong). Maybe some "I made them myself" brackets for a different mud gaurd then the stock RS one?
Charles Gallant
Thu Mar 06, 2008 3:44 pm » Post: #7 » Download Post
I think the way they've modded the top triple to take the NSR ignition switch is pretty trick!
The "boxes" on the bottom of the forks are definitely brackets for a different fender.
The calipers definitely aren't HRC. That's the same front-end as I have on mine, so I can be positive as I have HRC calipers.
There were no HRC carbs (not for the masses anyway) for the MC28. The do however look kitted. The red X-piece is an HRC item, and there is no reason not to believe they don't have/come with the HRC needles and jets etc., as it was a common HRC SS/SP kit. The bellmouths are after-market.
jkolewski
Fri Mar 07, 2008 1:11 pm » Post: #8 » Download Post
Are you looking or selling? If the price is right I may be intrested in the wheels.
1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
drschneider
Wed Mar 12, 2008 5:44 pm » Post: #9 » Download Post
this was a 1992 rs250r frontend.
Till 1991 it was a non USD, since 1993 they had the brembos.
nsr300se rs250rī05 ns-1rr
