NSR300 rebuild help
rodney007
NSR300 rebuild help
Wed Mar 26, 2008 11:53 am » Post: #1 » Download Post
after screwing my bottom end on the nsr (300cc)
i brought a m18 bottm end and swapped over everything and is now in..
(new pistons, rings, gaskets, cyclinder clean, pins, need rollers etc etc)
put over my sprocket, oil pump, water pump outlet, linked chain.
questions (please!!!)
motor was dry, now is wet clutch, can i use same clutch cable ?
and the clutch leaver under block has little (pull back)
to return the cable back, lol
reeds and vaccum pack things that sit above them, do i need to swap them over too?
is there ANY LINKS TO PICTURES OF ENGINES< without fairing, for reference to where the parts go after,
i forgot some mounting spots, please help thanks guys
THE 300 LIVES AGAIN! Very Happy
mick
Wed Mar 26, 2008 1:36 pm » Post: #2 » Download Post
Swap the clutches over. It's not a massive job.
rodney007
Wed Mar 26, 2008 5:40 pm » Post: #3 » Download Post
yeh i was going too, but after installing the 300 kit, the clutch started to slipout a bit on heavythrottle,
and im trying to minimise workload, and get this thing running, clutch can do later
rodney007
Thu Mar 27, 2008 5:51 am » Post: #4 » Download Post
ok can anyone know where this hose goes?
[img]http://img175.imageshack.us/img175/8967/87536057qs0.jpg[/img]
and am i right to say..
waterpump ---> radiator ----> thermostate housing ----> top of both heads
-------> out of both heads -------> waterpump return?
thanks guys, i need help Very Happy .. almost done
zxcvbnm
Thu Mar 27, 2008 7:41 am » Post: #5 » Download Post
Gearbox breather hose by the looks. Exits with the other breather/overflow pipes under the right peg on the 28.
I would have stuck a new crank in it if it was me.
rodney007
Thu Mar 27, 2008 9:36 am » Post: #6 » Download Post
not when your fixing to sell,,,.....
getting to expensive and i just brought a k4 gixxer 600
and i have a starion gsr,,,
UPDATE::::
bike runs, dont worry about the help!...
2 days Very Happy
JohnBlaze
Thu Mar 27, 2008 9:16 pm » Post: #7 » Download Post
You gonna do anything about the crank??? i notice you don't have anything listed. That's prolly gonna be you weak link with the 300 kit. Especially if its an older high mileage mc 18 bottom end.
MC21 300R w/SE bits, Rossi 2001
MC28SE Silhouette Repsol
Fri Mar 28, 2008 10:27 am » Post: #8 » Download Post
Well he can take it out and have it rebuilt now, or whoevers got the bike take it out and have it rebuilt if/when it goes, I know which I'd do.
rodney007
Fri Mar 28, 2008 12:50 pm » Post: #9 » Download Post
guys....
inbetween the gear selector and clutch leaver... there is a plug that goes into
the mc21 block that has sevral wires on it, removing it, you can see it has a o-ring on it, and at the end has small shaft with a key type thing at the end...
on new mc18 block, this plug has nowhere togo as it doesnt obviously fit this unit..
what is it.. do i need it?, engine runs without it...
thanks guys
p.s its a low-milege mc18,
mick
Fri Mar 28, 2008 1:16 pm » Post: #10 » Download Post
It's the GPS (Gear Position Sensor)
rodney007
Fri Mar 28, 2008 8:41 pm » Post: #11 » Download Post
ok thanks,,,,,
how do i not use it cause its on the mc21 luming?
tuck-it to the side?
Kieran
Sat Mar 29, 2008 3:12 am » Post: #12 » Download Post
Wire it to be set for one gear only...3rd is probably the best safe medium. The MC18 doesn't have a GPS.
The Chopster
rodney007
Sat Mar 29, 2008 4:30 am » Post: #13 » Download Post
so wire all wires to 3rd gear wire? then tuck it to the side?
the gps doesnt fit in my engine where does it go if i wire it like that
zxcvbnm
Sat Mar 29, 2008 6:53 am » Post: #14 » Download Post
Just join them using the wire splice guide but with out the sensor so it thinks it's in 3rd.
Only problem I can see it it will always think it's in gear and never show neutral.
rodney007
Sun Mar 30, 2008 4:58 am » Post: #15 » Download Post
hey the guide for setting rc valves, looks alot diferent to my 300 valves,
anyone know how to setup 300 pvowervalves?
NSR300 Discussion
