Rust on fork stems
sheamuz
Rust on fork stems
Sun May 25, 2008 12:38 pm » Post: #1 » Download Post
Is there anything that can be done about spot rust on fork stems such as replating. Is the fork surface a special type of chrome? Will replating effect fork performance (seal). Methods in preventing further spread of rust?
thanks
oiley NSR
forks
Sun May 25, 2008 3:00 pm » Post: #2 » Download Post
You will need to have them replated the chrome is a special chrome called hard chrome same as used on hydaulic rams on hevay plant diggers such as jcb and case .They will come out just the same as original as they grind the fork after chromeing back to stock size so seals unafected . Laughing
Sun May 25, 2008 3:42 pm » Post: #3 » Download Post
If it's very minor pitting and not going to effect seals too much, up round the yokes (triple clamps) or tiny pit marks for example, you can clean it up with Autosol metal polish or even localised wet/oil sanding with 1200 Wet'n'Dry. Thoroughly clean the chrome after, and then give it a wipe with ACF50 to prevent any corrosion seeping back in.
This will stave off rapid deterioration until you are ready to have the stanchions re-chromed.
My MC21 sat under a cover outdoors for the whole winter with all the exposed metal areas wiped over with ACF50, and it looked exactly as I left it 6 months ago when I lifted the cover off. It's expensive, but really good stuff. I coat everything with it now!
It cleans really well too, especially caked/baked on 2-stroke "spooge" from stainless pipes and engine casings, but don't get carried away as it will soon become an expensive cleaning medium! Confused
DifferentStrokes
Sun May 25, 2008 5:14 pm » Post: #4 » Download Post
o o
Last edited by DifferentStrokes on Mon Sep 28, 2009 8:05 pm; edited 1 time in total
Sun May 25, 2008 8:11 pm » Post: #5 » Download Post
I'd much prefer to clean something like the fork chrome by hand personally. Even a soft wire brush spinning at speed on an electric appliance can remove material very quickly.
You just can't beat a hand-job sometimes! Very Happy
Mon May 26, 2008 8:21 am » Post: #6 » Download Post
Yup, can't beat a hand job on your fescalised portions! Wink
p0lariso
Mon May 26, 2008 11:27 pm » Post: #7 » Download Post
This stuff works nicely on surface rust
http://www.nevrdull.com/
1996 MC28 SE
NSR250R2R
sheamuz
Sun Jun 01, 2008 11:02 am » Post: #8 » Download Post
Do any aussies know of any places in victoria where i could get the above mentioned from oileynsr. thanks for advice Arrow
nxrsr20
Sun Jun 01, 2008 8:55 pm » Post: #9 » Download Post
look in the back of a few of the bike mags for a place called "rad chrome" or something like that.
