Difference between Wet Cutch and Dry
Taji
Fri Jul 18, 2008 5:25 pm » Post: #1 » Download Post
Hi All,
I have been reading as much as I can but cant find the differences between the wet clutch version (se/sp) or the dry clutch version. Could someone please tell me the performance difference etc, OH and I remember reading about something that one sounds better than the other??
Tx
Taji
Fri Jul 18, 2008 5:38 pm » Post: #2 » Download Post
oops i mixed them up, se/sp is dry and "R" is wet, my mistake.
Fri Jul 18, 2008 5:40 pm » Post: #3 » Download Post
Quick run-down:
All MC16's are wet clutch
All MC18 Mk1's are wet clutch (including SP models)
MC18R5K - wet clutch
MC18R6K SP - dry clutch
MC21R - wet clutch
MC21SE/SP - dry clutch
MC28R - wet clutch
MC28SE/SP - dry clutch
Performance differences negligable, although it would make sense that the dry clutch motors are capable of slightly more power as the clutch assebly doesn't have to spin in oil.
Race derived dry clutches don't contaminate transmission oil as they wear, and can be serviced within minutes. Fully synthetic racing transmission oils can be used with dry clutches.
Wet clutches are quieter and more neighbour friendly.
Dry clutches sound the business... especially if you run them without the dampening rubbers! Very Happy
Formula 3 dry clutch kits were available for MC16 and MC18 Mk1 (rarer than hens teeth now), and many R and SE/SP motors will have had clutch swaps (both ways). MC18 Mk2, MC21, and MC28 assemblies are pretty much interchangeable.
MC16 and MC18 Mk1's will not take a later dry clutch without modification.
That's my helpful post for the weekend! Wink
80XAR
Fri Jul 18, 2008 11:39 pm » Post: #4 » Download Post
Sitting at lights with a dry clutch rattling away may entise wankers to tell that your weed eater needs a rebuild as it has bad piston slap.
