Battery not charging.
Manny Fagnet
Thu Aug 14, 2008 12:15 pm » Post: #1 » Download Post
I need a bit of help please.
Its an MC21 With a TYGA 300 motor (the Campsa Honda that was on the home page once)
I recently got home from a trip to Scotland (1000 miles in 3 days). On the last leg the bike ran but I lost all lights. All except some glimmers in the warning lights.
Optmate brings the battery back fine but it quickly returns to nothing when out with the headlight on.The bike actually runs fine though.
Before I get too involved with the spanners, (I don't know what I'm looking for) is there a simple check with a meter that may pinpoint the fault.
I'm hoping just a replacement regulator will do it but electrics baffle me.
If thats the case has anyone got a spare on a shelf?
Thanks for reading this, Mal.
if it had a tail - it would wag
jeff350lc
Thu Aug 14, 2008 1:53 pm » Post: #2 » Download Post
Put a multi meter across the battery with the engine off and check voltage, helps if it's a little flat.
Start the engine and hold the revs up a bit 2000 - 3000 rpm should do it. You should have a reading of 12.5 up to 14.5 volts. If not pound to a penny its the reg. you can get them from that internet site that Andy dislikes. But i never told you that Wink
Check all the connections first though, don't forget the earths.
Manny Fagnet
Thu Aug 14, 2008 7:38 pm » Post: #3 » Download Post
Thanks . I'm onto it at the weekend.
banshee
1996 Honda NSR250MC28SE
Thu Aug 14, 2008 8:43 pm » Post: #4 » Download Post
also a bit of a tip!!!!
my regulator went on me and i fitted a new blackbird one !!!! ( A LITTLE MORE HEAVY DUTY )
Though you can only get one bolt through it !!!!!!
Manny Fagnet
Fri Aug 15, 2008 7:40 pm » Post: #5 » Download Post
Thanks for the tip. I'm grateful.
watfordhorn
1995 Honda NSR250 MC28
Fri Aug 15, 2008 10:43 pm » Post: #6 » Download Post
sounds like the tyga subframe has fried another rectifier Rolling Eyes
Fri Aug 15, 2008 10:45 pm » Post: #7 » Download Post
Some one nice has bolted a big fat lump of ally to mine and attached the reg/rec to that, and flipping heck that bit of metal gets too hot to touch.....
Sat Aug 16, 2008 10:28 am » Post: #8 » Download Post
If you don't have a decent chunk of frame to act as a heatsink for the reg/rect then you really ought to get a plate on it, or buy one with fins. Sticking it in some airflow is also gonna help. They have to dissipate all the excess voltage / current generated when your engine is spinning at high revs, and if there's nothing to take that heat away, they fry.
Manny Fagnet
Sun Aug 17, 2008 8:30 am » Post: #9 » Download Post
Just checked it and......
Battery reads 12.6V when stood, ignition off.
Then 14.7 when the bike is on idle.
Then 20.8 at a steady 3,500 revs, and I suspect it just climbs from there.
I did notice the faintest bubble trying to emerge from where the battery was sealed after filling from new too.
Is this all a symptom of the regulator please?
If so can someone quietly point me in the direction of a replacement, Thanks again.
Sun Aug 17, 2008 10:25 am » Post: #10 » Download Post
Yes, it's toast. Don't ride the bike until you've replaced it as you can damage other things not designed to run at 20v.
Just about any Honda unit will do, and most aftermarket ones too. They pretty much all work on the same principal. As someone has said, a Blackbird reg/rect will fit and is a little more robust, so why not contact one of the aftermarket guys like M&P or MPS and get a pattern one?
Manny Fagnet
Sun Aug 17, 2008 5:16 pm » Post: #11 » Download Post
thanks for everything.
