MC21 swinging arm into MC18?
hutch
Sat Jan 17, 2009 11:00 pm » Post: #1 » Download Post
Is this conversion possible? It would give me a 17 inch rear but i also love the shape of the 21 arm.
Come to think of it i'll rephrase that question as anything can be made to fit with enough money and the right tools. question should read "is this an easy conversion?"
Ta Guys
Sat Jan 17, 2009 11:25 pm » Post: #2 » Download Post
I've seen it done on an R5K and an MC16. NSR.Wayne reported it needed modified link plates when he tried it on one of his MC18's, but didn't have time to experiment*. I would think you can probably do it with a mix'n'match of stock MC18 and MC21 parts though.
17" MC21 wheels will slot straight into an MC18 swingarm though, so you don't need to change it just to run a different wheel.
*Probably too busy building "special" gearboxes with Jeff350lc! Laughing
Sat Jan 17, 2009 11:37 pm » Post: #3 » Download Post
The '18 has classic lines. Keep the stock swinger. Be proud of what you have.
Chester362
Sun Jan 18, 2009 12:18 am » Post: #4 » Download Post
As Steve says, I too like the classic look of the MC18.
I`ve got a white rear MC21 wheel I was going to put on the classified section for £50 soon. It needs a paint or powdercoat job doing really though.
hutch
Sun Jan 18, 2009 1:10 am » Post: #5 » Download Post
Cheers for the reply guys and i understand what your saying about the classic lines. I suppose the 18 is rarer than the 21 and i should keep the overall look. Chester, i'll take that wheel off your hands.Drop me a pm.
Sun Jan 18, 2009 8:34 pm » Post: #6 » Download Post
Well done that man!
If you go the 17" route you will then need to adjust the ride hight which can be done with a set of home made linkage plates. The template for teh HRC ones is in the workshop tech section.
The Mc18 is already relaxed as stock so it does improve it quite a bit.
dunkenb
1989 Honda NSR250 MC18
Fri Jan 23, 2009 7:04 pm » Post: #7 » Download Post
anyone know if an nc29(cbr400rr gull arm) swingarm will fit an mc18?
Fri Jan 23, 2009 7:07 pm » Post: #8 » Download Post
You'd have a much better chance of getting an NSR one to fit. At least it's the right width and the shock mount's in the right place to start with!
Fri Jan 23, 2009 7:12 pm » Post: #9 » Download Post
Burn him Andy, or make him buy an RGV, which ever you think is worse!
Fri Jan 23, 2009 7:20 pm » Post: #10 » Download Post
4T bits on an NSR... where are our white hoods Steve?! Laughing
Fri Jan 23, 2009 7:27 pm » Post: #11 » Download Post
put a what Shocked in where Shocked round up the boys we is having a lynching Laughing
Fri Jan 23, 2009 7:27 pm » Post: #12 » Download Post
No idea, I havn't had to wear mine since that guy came on talking about fitting DR400 engines into NSR frames!
dunkenb
Fri Jan 23, 2009 7:34 pm » Post: #13 » Download Post
it was only a thought....... i shall now go into hiding! lol Hmmmm! DR400 you say????
dunkenb
Mon Jan 26, 2009 9:15 pm » Post: #14 » Download Post
if you put a 21 wheel in an 18 can you use the 18 spacers or do you need 21 spacers ( or are they the same anyway) ????
