Do any of you guys know how much fork oil each leg of an MC21 should hold please? After draining and measuring mine both are different.
And also where I can buy a decent set of fork oil seals? I bought some cheapies off that auction site and after a couple of hours at Cadwell yesterday one had gone again. They did look pretty cheap and nasty when they arrived but I havent been able to find any more.
Cheers Andy - simply read the instructions on the can. Should have known. Its -5 degrees in the shed and my brain was obviously malfunctioning. Only problem is I haven't got enough fork oil.
Yeah, that could be a problem! I personally mix 10w and 15w fork oil, but I'm a little large compared to the average Japanese rider I imagine!
If you are closer to the ideal weight for an NSR (50~70kg), or if the suspension has been revalved, then 10w is much better as a thinner oil will always work better than a thicker one. _________________ Andy.
