I have just received my barrel from the platers and was wondering about the ring gap . What is the recomended ring gap for a race bike with wiseco pistons
There's no answer otherwise, as Honda only provide a figure for standard 250 pistons, which may not be suitable for your application. _________________ Andy.
I used the calculations and came up with a ring gap of 0.24 mm .
Does this sound normal to you guys ?
On the box it talks about 0.051 piston clearance .
manual shows stock ring gap to be Top 0.30-0.45 and the same for bottom. have no clue what that means for a wiseco piston/ring. _________________ Charles Gallant
The reason i ask is because when i measured my rings they were at 0.4mm after half a season of racing with 62 bhp . Iput fresh rings only and got back up to 68.5 bhp with a ring gap around 0.2 something .
