think the bits on the left of the pgmIII are power valve gubbins.
sure someone will correct you if your wrong.
as far as i can tell its in the same position on the pgmII i have on my mc18
To me it looks like a dead fet a 2sk1059. in the pgm
I have done some digging and it seems that honda have
discontinued the regulator that that MC21 came with the sh609-12
and replaced it with a part numbered 31600-MV4-010
Has anyone tried one of these 31600-MV4-010 regulator on
an NSR ?..
I also have a regulator off an mc18 some place if I can find it
wil that work on the mc21 ?
I can also try the mc21 servo on my mc18 if they are the same part.
Any reg/rec will work if you wire it in properly. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
I'm going to wire in a 6 wire regulator as i'm told the 5 wire type that's on the
NSR is well know to kill pgm's.... i'm told the nc30's have the same problem....
I just tested the servo from my mc21 on my mc18 and it's fine...
