I cannot get my powervalve servo (PVS) to work. I've built the bike up from a non runner, so I assume the PVS activates the PV and they complete a cycle when you turn on the key? Mine doesn't. Infact they don't work at all, even when the bikes rev'ed beyond 8000.
Thanks Andy, I had read the tuning section on setting the PV and disconnecting the TPS block connector. My problem is that I can't get the powervalve / servo to work at all.
Assuming the valves are free, try removing the servo from frame then remove the pulley and seperate the top and bottom of the servo, be careful as theres quite a few plastic gears in there.
Eventually the motor and the potentiometer will be revield, a simple test on the motor and the pot can be made.
Burnt out motor, snapped wire faulty pot etc.
Never had chance to give the exhausts a good airing yet then!!
