28 final drive gearing/sprocketing input please.
RaceFan
1993 Honda NSR250 MC28SP
Wed Jul 15, 2009 8:13 am » Post: #1 » Download Post
My bike revs out too far on the long straights but at the same time, that doesn't equate to much actual top speed.
Neal shared some info on his 21 sprocketing with me for the same track I am at this weekend. (His times are fast so I rate he is a good source for info). Stuck that into a gearing calculator along with the two bikes box ratios to try and come up with some sprocketing for the 28.
The calcs tell me to run a 15/41 combination. Anyone run this sort of gearing or have any input on it.
If you want a proper 2 stroke get an RGV.
Wed Jul 15, 2009 8:57 am » Post: #2 » Download Post
I ran a 42 rear on my MC21 for the track, livens up the acceleration and I don't think I ever found full top speed anywhere.
Saying that, I've never ridden it at Donnington...
RaceFan
Wed Jul 15, 2009 9:38 am » Post: #3 » Download Post
The 28's stock is 15/44 so it is already pretty low gearing.
I'm in top gear and at peak power just over half way down my regular track's back straight, By the time I get to the braking point I'm well into the red and waiting for the thing to blow up or run lean.
Next question, are the 21 and 28 sprockets the same?
Wed Jul 15, 2009 11:05 am » Post: #4 » Download Post
Front sprocket? Yes. Rear? No. And neither is the gearbox or primary drive ratio.
I ran 15/39 on my '28 (which I believe was totally 28se) and it was flat out by the Dunlop Bridge.
I ran 15/40 on my mc18 (unknown box, but as it's a dry clutch, probably a '21) and was flat out about 2/3rds of the way along the "straight" between Church and Rocket at Anglesey, swapped the front to a 16 and instantly went 4 seconds a lap faster Shocked
RaceFan
Wed Jul 15, 2009 12:03 pm » Post: #5 » Download Post
fontyyy wrote:Front sprocket? Yes. Rear? No. And neither is the gearbox or primary drive ratio.
Thanks, I do realise the boxes are different and calculated as such.
Neal
Wed Jul 15, 2009 6:46 pm » Post: #6 » Download Post
Howzit , go I have a 16 front srocket if you want to try it !At Phakisa , you want to come onto the backstraight in 4th changing into 5th , 6th should rev out as you hit the apex of the right hander . You hold it flat out in 6 th gear and the two corners bcome one . Watch out for the ripples on the exit of the corner , have fun !Neal
Wed Jul 15, 2009 6:47 pm » Post: #7 » Download Post
I ran a 16t once Shocked
Wed Jul 15, 2009 10:44 pm » Post: #8 » Download Post
Well done Stephen....
RaceFan
Thu Jul 16, 2009 5:41 am » Post: #9 » Download Post
Neal wrote:Howzit , go I have a 16 front srocket if you want to try it !At Phakisa , you want to come onto the backstraight in 4th changing into 5th , 6th should rev out as you hit the apex of the right hander . You hold it flat out in 6 th gear and the two corners bcome one . Watch out for the ripples on the exit of the corner , have fun !Neal
16 sounds like a good fix since I might not be able to get rears cut before the weekend.
I'll take your word on hitting that 6th gear flat out Wink I'll walk before I run thanks. Laughing
