I am in the process of carrying out a few mods to my MC28.
I am fitting a set of M-max pipes, boring out the carbs, as per max recommended (33.5mm). fitting hi flow air filters, and carbon reeds.
My experience of jetting is limited, so would appreciate any recommendations as to size of main jet etc, before I start the bike and have it seize on me.
I don't allow jetting discussion in the public area. People are welcome to PM you with advice, but if you wish to discuss it in open you will need to join as a supporting member and post in the Setup area. _________________ Andy.
Normally I'd drop you a PM straight away, but once you're playing with the carb bores I have no idea what effect that has.
Make sure the person who's advice you follow does..... _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
And that will be exactly why I don't allow specific jetting discussion in the public forum.
"almost the same as Jeff. HRC jet kit carb, Dogfight can etc..." is not the same is it, and could require extremely different settings. _________________ Andy.
wahzai wrote:almost the same as Jeff. HRC jet kit carb, Dogfight can etc...
You've got the jet kit, it would appear Jeff hasn't, that's quite a big difference!
HRC base settings are in the tuning section... _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
