HRC Head Conversion Spark Plug
mixalisen
Tue Aug 04, 2009 9:25 am » Post: #1 » Download Post
Hi guys...
i was looking what spark plug i have to use in order to have enough clearance between the spark plug cap and the front wheel and i found the NGK R7282... The good thing about this type is that is produced in many heat grades 7-8-9-10-10.5 and 11...
http://www.ngk-sparkplugs.jp/english/raceinfo/sparkplug/02/index.html
The question...: Is this type R7282 suitable for my MC28...?
This type of spark plug uses the NGK TRS1225 cap... But i can't find it in Greece... Do you guys have access to this type of cap...? Is there any internet shop that sells this type of cap...?
http://www.ngk-sparkplugs.jp/english/raceinfo/sparkplug/03/index.html
Michael
Kieran
Tue Aug 04, 2009 10:35 am » Post: #2 » Download Post
Suitable but very expensive...
Try the NGK R5300A range of plugs. Also a shorty type plug, as good as the 7282's, but cheaper. I think the 7282's are set up for det counters, (don't quote me on that)...
I have used R5300A-105's.
The Chopster
Kieran
Tue Aug 04, 2009 10:41 am » Post: #3 » Download Post
Just checked at:
http://sparkplugs.com/results_cross.asp?pid=R6252E-105&x=67&y=16
R5300 is now obselete, discontinued Crying or Very sad
Replacement is:R6252E-105 Trying to find out more now...
The Chopster
mixalisen
Tue Aug 04, 2009 12:01 pm » Post: #4 » Download Post
Thanks Kieran,
But what type of cap must be used along with the R6252E-105 spark plug...? Is this also a short type of spark plug...?
Tue Aug 04, 2009 12:33 pm » Post: #5 » Download Post
yes their short plugs mate
RichG
Tue Aug 04, 2009 2:51 pm » Post: #6 » Download Post
http://www.camskill.co.uk/products.php?plid=m18b572s1283p4898&rs=gb
Rich
mixalisen
Tue Aug 04, 2009 3:15 pm » Post: #7 » Download Post
Great find Rich...
Thanks... That helps a lot...
mixalisen
Tue Aug 04, 2009 3:31 pm » Post: #8 » Download Post
About the cap...? Does the TRS1225 suit to the R5300 plugs...? Or i have to use another cap...?
Tue Aug 04, 2009 3:40 pm » Post: #9 » Download Post
i think they would be ok but i cant check what my caps are as the bikes not with me
Kieran
Wed Aug 05, 2009 5:23 am » Post: #10 » Download Post
TRS1408 is the plug cap you want
The Chopster
mixalisen
Thu Aug 06, 2009 10:23 am » Post: #11 » Download Post
Thank you all you guys for your inputs...
