A couple of Q's on Derestricting..
2Smoke
1987 Honda NSR250 MC16
Thu Feb 11, 2010 10:29 pm » Post: #1 » Download Post
Hi, as part of fitting the mc18 loom and pgmII to my mc16, I've been looking as to how they are de-restricted.
Now the wire splice, I'm happy with but the gear position/speed limiting thing Is keeping me in the dark. I dont have the gps on my mc16, so how do I go about fooling the pgm into thinking its in 3rd? Also there is an m-max de-restrictor on the loom but its attacked to the pgm main plug and goes nowhere bar a looped 3-pin spade connector, guessing this is to go to the gps?
What do other racers do with the mc18's loom?
Paul
mike1972
1991 Honda VFR400 NC30
Thu Feb 11, 2010 10:37 pm » Post: #2 » Download Post
hi paul , there,s no gps on the mc18 , you only need to do the wire splice to de-restrict it
Neal
Fri Feb 12, 2010 5:18 am » Post: #3 » Download Post
Have you done the wire connection inside the pgm 2 . We got 1.5 hp extra for free !
2Smoke
Fri Feb 12, 2010 9:11 am » Post: #4 » Download Post
Mike, cheers for that. Got a bit baffled last night with it!
Neal, how do i go about doing that? Not had my pgm's yet..
Paul
Fri Feb 12, 2010 12:11 pm » Post: #5 » Download Post
It's not really a derestirction, it advances the timing, if you're setup wants the timing advancing, it'll give a bit of power, if it's on the edge anyway it'll reduce your front piston to a glob of molten ally.
