Last week I finally started to get all my new TYGA bits on my 28SE. Unfortunately the garage fitting these parts found that I need a new TPS and one of the hoses off the carbs is split. I have a spare MC21 carb assembly, would it be possible to swap them?
Thought I'd share a pic of my bike with the TYGA chambers.
nsrdownunder wrote:Hi Mate
I would use the 21 carbs they are a lot easier to work on and will go straight on.
thats right, easier needle removal than mc28's , and the diameter is larger.. im using a MC21 carbs + hrc kit on my MC28 SP , works equally if not better than the MC28's.. only flaw is , the air box of MC28 wouldnt fit anymore and running open carbs with an female stockings over it its just a match made it heaven
