Just wondering if anyone has run one cylinder with an H barrel and head and the other an L barrel and head. Do the different combinations put out the same power? I'm asking because I have one lone H barrel and in a pinch I'd like to be able to use it (with the appropriate head of course).
Why in the world did they make 2 combinations anyway?
Yep, my original '21 came that way. Not sure if it made any difference to the power. I certainly didn't notice once I'd "corrected" the setup.
My understanding is that it was a work around to give a few more options re production racing rules - such as raising compression while still using standard parts.
If you think the R/SP cylinder setup is difficult, be thankful you didn't buy a TZR 3XV.
The combinations are to allow them to make high compression engine without modifying any stock parts.
And yes, I've raced on a half L half H motor. Once assembled it's pretty irrelevent which you've got as long as they're a matched set. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
