Mild steel TYGA pipes...
Mon Apr 05, 2010 2:47 pm » Post: #1 » Download Post
Gavin at Jap4 has a great deal on a limited run of mild steel TYGA pipes in the Members section, in case anyone missed it.
GrantA
Mon Apr 05, 2010 3:02 pm » Post: #2 » Download Post
cheap price that but how will the mild steel compare to the stainless as regards to rusting?
are they coated?
i have always liked the gp style but...
do the gp style fit on with no mods to the bodywork?
also do the gp pipes give less performance than standard front pipes?
Mon Apr 05, 2010 6:23 pm » Post: #3 » Download Post
That is a good price, with ally cans and Ti members discount thats £279 posted!
According to Tyga they are clear coated.
Chester362
Mon Apr 05, 2010 10:33 pm » Post: #4 » Download Post
GrantA wrote:cheap price that but how will the mild steel compare to the stainless as regards to rusting?
are they coated?
According to one of the Tyga projects, the GP style chambers gave slightly more than the normal side by side Tyga pipes.
I personally like the staggered side by side pipes over the RGV-alike GP pipes.
I`ve been wanting Tyga to do the NSR pipes in mild steel for a while now. Think a visit to Gavin`s will be on the cards soon!
gavin jap4
Tue Apr 06, 2010 3:05 am » Post: #5 » Download Post
are they coated?
The chambers are designed to give clearance to the swing arm and stock footpeg hangers as well as work with our Tyga Performance step kit STAA-0002. The stock bodywork does not need to be cut, unlike when used with some other manufacturer's chambers. (though repositioning of rear lower cowling down by 25mm is recommended)
pipes come clear coated for protection
GrantA
Thu Apr 08, 2010 6:55 pm » Post: #6 » Download Post
ordered mine. set of gp pipes. Cool
gavin jap4
Fri Apr 09, 2010 4:41 pm » Post: #7 » Download Post
all shipped out today for you so should arrive on monday
GrantA
Fri Apr 09, 2010 7:03 pm » Post: #8 » Download Post
gavin jap4 wrote:all shipped out today for you so should arrive on monday
nice. Cool
Major_Tom
1994 Honda NSR250 MC28SE
Fri Apr 09, 2010 11:36 pm » Post: #9 » Download Post
Myself and a friend recently fitted TYGA SS chambers to our bikes and we both had to slightly cut our fairings to get them to fit properly.
Sat Apr 10, 2010 1:24 pm » Post: #10 » Download Post
You can actually get TYGA pipes to clear the bodywork without cutting, but it takes some jiggling. You need to space one side out a little, and drop it down about 20mm I seem to recall.
You can certainly fit them without cutting the bodywork though.
GrantA
Sat Apr 10, 2010 2:40 pm » Post: #11 » Download Post
i am Glad they will fit without cutting as i dont mind a little jiggling but would not want to cut the fairing.
i will let you know how they fit when i have had chance to get them on.
Sat Apr 10, 2010 4:33 pm » Post: #12 » Download Post
I think TYGA used to have a fitting guide on their site before, and Paul did tell me a long time ago they were going to include fitting advice in with the pipes, but it sounds like that idea got forgotten over time.
I'm sure a PM to Matt@TYGA would get you the information needed, although I am positive he's already posted all about it on the Forum before.
Please don't just PM Matt with general pipe questions unless you have TYGA's though... I've seen some of the e-mails and questions he gets about non-TYGA products (mind you, I get my fair share of rubbish myself! Laughing) and wading through it all is exceptionally time consuming and only prevents him from spending time productively!
GrantA
Sat Apr 10, 2010 6:30 pm » Post: #13 » Download Post
Andy wrote:I think TYGA used to have a fitting guide on their site before, and Paul did tell me a long time ago they were going to include fitting advice in with the pipes, but it sounds like that idea got forgotten over time.
hopefully he might read this thread and give us some input about fitting.
if not if i get any problems i will send a PM for some advice.
Andy i might be contacting you in the near future about the price for some port optimisation work from nsr-world. thats next on my list along with a top end overhaul. Smile
Mon Apr 12, 2010 4:07 am » Post: #14 » Download Post
No, I haven't read this thread Smile
The pipes will go on without cutting the bodywork.
Without changing our pipe's dimensions we really can't fit them without at least a little interference, and found that on one of the bikes we kept the left side lower in the original mounting position, but the right side lower needed spacing out about 5mm and dropping about 20mm. Another bike needed this spacing on both left and right lowers.
Strange that they should be so different, but I've seen so many differences in other aspects, so I guess it just depends on if all the production tolerances work for you or against you.
Try to keep the spacing as minimal as possible to retain ground clearance. However, it's unlikely that you'll suffer touch down issues unless you're on the race track. 3~4mm clearance seems to be adequate.
Moons ago when I rode the MC28, Harc-Pro gave me support and their pipes required quite a chunk cutting off the lower right side cowl to get good fitment. Upon asking they just told me that that's how it was.
I've tried as best I can to get the pipes as inboard as possible without compromising design, and this is the best I can come up with using the current spec.
One way around it is we could make the pipes fit the fairing, but then you guys might not be so keen on the idea of pipes that fit, compared to pipes that work. Well, that's my theory and I'm sticking to it.
In contrast, our TYGA bodywork is designed around the pipes.
Mon Apr 12, 2010 8:35 am » Post: #15 » Download Post
What I found worked was to use a pice of wooden batten (about an inch by half inch) with one end screwed to the frame and the other screwed to the fairing.
From memory it was about an inch and a half long...
