Using A747 "immediately"
craigsutton
Sat Apr 10, 2010 1:29 pm » Post: #1 » Download Post
I'll be jetting my track bike over the next few days. Yesterday I bought 5 gallons of fuel and mixed it with my (very expensive) A747 oil. Then I read on here it should be used "immediately". Will a couple days be okay, especially if I shake up the gas can before putting fuel in the tank each time? Anybody had any problems with seperation?
Thanks,
Craig
Sat Apr 10, 2010 1:58 pm » Post: #2 » Download Post
Yes, a few days will be fine. It does break down quickly though, so yes you should ideally only mix it the same day or night or two before you use it.
Make sure you give the can a bloody good shake before you pour it in... something you should do with any pre-mix, not just castor based ones! Wink
cgallant
2001 Honda RS250
Sat Apr 10, 2010 2:08 pm » Post: #3 » Download Post
Craig,
I generally mix my fuel as I use it. I have a smaller 2 gallon fuel can I mix in. So just before I go out for a session, I will mix a gallon or so at a time, put it in the bike and run the session. This way I don't have any left over pre-mix (or as little as possible) at the end of the day/weekend.
The leftover useally goes in my crappy push mower (which after years of abuse, still starts right up and runs strong!). Also when using A747 and race fuel, you wll want to drain your tank after the day/weekend. Don't really want to keep it in the tank for extended periods of time.
Oh and also you will want to drain your carbs as well when your done.
craigsutton
Sat Apr 10, 2010 2:28 pm » Post: #4 » Download Post
Thanks guys, I appreciate it. Starting to feel like a real racer now LOL.
Neal
Sat Apr 10, 2010 7:35 pm » Post: #5 » Download Post
Just remember that A747 was designed for leaded fuel and XR77 is for unleaded fuel if you really are fussy .
nxrsr20
Sat Apr 10, 2010 10:02 pm » Post: #6 » Download Post
so what happens when the oil breaks down? Does it lose it's lubricating properties or does other nasty things to petrol?
Tue Apr 13, 2010 12:23 am » Post: #7 » Download Post
To be fair, if you're running a motor so hot you think it needs A747 you should probably be more concerned about the effect of leaving your (no doubt equally expensive) race fuel open to air.
Most proddy 250 racers I know just run decent quality synthetic oil.
craigsutton
Tue Apr 13, 2010 3:02 am » Post: #8 » Download Post
FYI Fontyyy I'm only running it to irritate you. Hopefully you find it hard to fall asleep for several nights now wondering "why oh why does Craig find it necessary to run A747 in his bike when he hasn't even yet learned to drag a knee??".
Laughing
Tue Apr 13, 2010 8:12 am » Post: #9 » Download Post
It doesn't irritate me - I've got shares in Castrol, but it does amuse me a little Wink
Back to the subject;
Unless you're running leaded race fuel (or Avgas) A747 is the wrong oil, X77 is Castrol's top 2t race oil for unleaded fuel.
And both are castor based and have a higher shear strength than synthetic oil but they (and A747 especially) are a pain to mix, don't like being kept in the cold, don't store well, are expensive and will gum your rings up.
Tue Apr 13, 2010 9:23 am » Post: #10 » Download Post
Adding to Fonyyy's observations......if you run A747 or XR77 you'll want to run the carbs out of fuel before shutting down. This is not optional!
Tue Apr 13, 2010 9:48 am » Post: #11 » Download Post
Is that the voice of hard experience speaking there Matt?
craigsutton
Sun Apr 18, 2010 8:06 pm » Post: #12 » Download Post
So how does switching to TTS for all of my NSRs sound? I use it for the injected (street) bike, so I could buy more of it at a time and have a large stash at home to use for whichever one needs it.
Sun Apr 18, 2010 8:41 pm » Post: #13 » Download Post
Nothing wrong at all with TTS... in either injector systems, or pre-mixed. Fine oil, and smells nice too!
Sun Apr 18, 2010 10:11 pm » Post: #14 » Download Post
craigsutton wrote:So how does switching to TTS for all of my NSRs sound? I use it for the injected (street) bike, so I could buy more of it at a time and have a large stash at home to use for whichever one needs it.
Fine, I switched from X77 to synthetic oil in my racebike. All I did was dump the last bit of fuel/x77 from the tank into the genny and fill up with a fresh fuel/synthetic oil mix.
craigsutton
Mon Apr 19, 2010 1:39 am » Post: #15 » Download Post
Yuck ... I just got done cleaning out the fuel tank and carbs on the track bike. Of course I had added a bunch of fuel to the tank right before it got windy and started spitting rain and snow, so I decided to leave for the day. Having that A747 mix in it made me want to get it out of there asap so I did that today and had to go through the slow and messy process of draining the tank and removing the carbs to get them cleaned out. I really don't want to have to go through that again!
The TTS will be safe to premix and not worry about if it's in there for a couple weeks right? I'll try and not mix too much at a time but this cleaning it out is a major pain!
Thanks for the replies. It'll be nice to have one oil for the bikes instead of two.
Craig
