Hi all,
I'm going to use a set of MC18 carbs on my MC16, so I don't have any air solenoids!
I have been searching though the forum and understand that I need to "block" the air pipes with something like #170 main jets.
I understand that Matt from Tyga have been running a somewhat equal setup on a MC21?
I will of course need to jet the carbs to suit my setup but that's not a concern at present.
Each MC18 carb have two air tube connectors. And as seen in the technical section I have an X-connector and a T-connector (http://tech.nsr-world.com/nsr/mc18/mc18-power-jets/).
If someone could explain where I should add restrictors (main jets) I would appreciate it very much...
