MC21 front brake line length
CircuitR
Fri May 14, 2010 5:50 am » Post: #1 » Download Post
Hi guys, tried searching but nothing would come up.
I'm going to get some Hel brake lines made up as the guys I'm using don't have the pre made kits. So I need to know what the length of the two lines would be. I roughly measured around 700mm, does that sound right? Or is that a bit long?
Blair
Canuck13
Fri May 14, 2010 8:01 am » Post: #2 » Download Post
i have a set of new Hel lines for a 21 that become redundant when I decided to change to a rvf front end. drop me a pm if your interested
CircuitR
Fri May 14, 2010 8:34 am » Post: #3 » Download Post
Cheers, but I'm getting a pretty good deal through these guys here in NZ.
Could you perhaps measure them for me? As the front end I have didn't come with them as the previous owner kept them for his new front end.
Cheers.
Canuck13
Sat May 15, 2010 3:07 am » Post: #4 » Download Post
no probs, but i am now overseas for a couple of weeks Sad bloody work
MrBear
Sat May 15, 2010 2:02 pm » Post: #5 » Download Post
just measured up an old set and here's what i've got:
Taking a centre line down the hose from the centre of
each banjo 585mm and 615mm.
done the same but to a centre line running through the
90degree angles bottom arm 560mm and 590mm.
My braided hoses are between 50 and 100mm longer,
hope this helps
Sat May 15, 2010 9:46 pm » Post: #6 » Download Post
What a brilliant first post, thank you MrBear and welcome to the Forum!
CircuitR
Sat May 15, 2010 10:01 pm » Post: #7 » Download Post
MrBear wrote:just measured up an old set and here's what i've got:
hope this helps
Wicked! Thanks for that. I though 700mm was close. I'll be getting them made up this week. I think I'll go red with stainless banjos.
Thanks again.
