Hi guys, tried searching but nothing would come up.
I'm going to get some Hel brake lines made up as the guys I'm using don't have the pre made kits. So I need to know what the length of the two lines would be. I roughly measured around 700mm, does that sound right? Or is that a bit long?
Cheers, but I'm getting a pretty good deal through these guys here in NZ.
Could you perhaps measure them for me? As the front end I have didn't come with them as the previous owner kept them for his new front end.
Cheers.
just measured up an old set and here's what i've got:
Taking a centre line down the hose from the centre of
each banjo 585mm and 615mm.
done the same but to a centre line running through the
90degree angles bottom arm 560mm and 590mm.
My braided hoses are between 50 and 100mm longer,
hope this helps
What a brilliant first post, thank you MrBear and welcome to the Forum! _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
MrBear wrote:just measured up an old set and here's what i've got:
hope this helps
Wicked! Thanks for that. I though 700mm was close. I'll be getting them made up this week. I think I'll go red with stainless banjos.
