kick starter disassembly
Jim
Mon Jun 07, 2010 3:51 pm » Post: #1 » Download Post
On an MC21, once the circlip is removed from the kick starter, how does the kick starter lever separate from the base (or what the parts manual calls the joint kick arm (28302-KV3-830)? I would assume it is supposed just to lift up and off, but mine is not budging, so I'm wondering if there is some other method? (the "kicker' is I had this off once before, and now I can't remember how I did it, which makes me think even more it should just be lifting off Embarassed ). Thanks.
-Jim
'93 MC21
Mon Jun 07, 2010 5:46 pm » Post: #2 » Download Post
You need a bigger hammer! Shocked
Jim
Mon Jun 07, 2010 7:43 pm » Post: #3 » Download Post
okay, so assuming you've not been talking to my wife, i take your comment to mean it should just pull off and I can beat if off...so to speak?
Thanks.
-Jim
'93 MC21
Jim
Tue Jun 08, 2010 8:02 pm » Post: #4 » Download Post
seriously, can someone please tell me how these pieces are supposed to come apart? I've removed the circlip but trying to pull the top piece up and out is not working, nor is a fair amount of hitting it with a hammer. Something is buggered or I am totally missing how this is supposed to separate. I want to get the "pin" out so I can add a wave washer to take up some of the slack and keep the lever from wiggling around when riding. Any help appreciated.
http://www.ephotobay.com/share/img-0356.html
-Jim
'93 MC21
NSR-lizard
Sat Jun 12, 2010 12:22 pm » Post: #5 » Download Post
Dave Ett wrote:You need a bigger hammer! Shocked
I second the motion!
There`s a ball bearing and a spring (not a pin) in the lever, that can sometimes stick if it rusts a little, or the grease goes hard. Squirt some 3-in-1 light oil in there.
Vampire?
Jim
Sun Jun 13, 2010 12:07 am » Post: #6 » Download Post
yeah, I remember the ball bearing and spring from when I had it apart before - you're likely right that it is stuck in there, probably from corrosion - I didn't have any problem getting it apart the first time, which why this has thrown me a bit. I'll try shooting some oil in there and hope for the best. Thanks!
-Jim
'93 MC21
