Help need:Can't make my mc28 running
atolldevil
Fri Jul 16, 2010 1:06 am » Post: #1 » Download Post
My mc28 is not running, is anyone have a cue?
My bike is sit in my garage more then half year, so the first thing I do is replace new spark plugs(radium), gas(91octane) and 2t oil(redline).
When I try to kick start my bike, I saw some smoke coming out from exhaust. So I think there is no problem with firing.
I kick many time, it still do the same thing, so I have no ideal wt happen to my bike.
Is anyone can help?
Thank you
JohnBlaze
    Send private message View user's profile Visit poster's website AIM Address
Fri Jul 16, 2010 1:08 am » Post: #2 » Download Post
did you check you battery?
MC21 300R w/SE bits, Rossi 2001
MC28SE Silhouette Repsol
atolldevil
Fri Jul 16, 2010 2:56 am » Post: #3 » Download Post
my battery is new, purchase in mid June, and i check, it is good.
Fri Jul 16, 2010 8:00 am » Post: #4 » Download Post
Try bump starting it, it's not unusal for them to not like starting after sitting around for a while.
Fri Jul 16, 2010 9:30 am » Post: #5 » Download Post
I suspect the carbs are a little gummed up. Did you drain all the old fuel out of them before you stored it, and if not have you done so now?
Old fuel does go off and loose it's octane rating...
atolldevil
Fri Jul 16, 2010 5:11 pm » Post: #6 » Download Post
thanks guy...
i clean my carbs today, when i putting it back i saw one of the exhaust valve control cable broken. i think it is the reason cause the bike is not running.
80XAR
Fri Jul 16, 2010 11:50 pm » Post: #7 » Download Post
It will still run with even if the powervalves are not working. Not very well, but it will still run.
atolldevil
Sat Jul 17, 2010 4:13 am » Post: #8 » Download Post
if the powervalves are not working, it will still run.
then i have no cue wt to look for now...
if anyone know what is wrong with my bike
thank you
Sat Jul 17, 2010 4:14 am » Post: #9 » Download Post
Please do not post TXT on the Forum.
atolldevil
Sun Jul 18, 2010 2:48 am » Post: #10 » Download Post
sorry...i am changed..
caffeinejoe90
Mon Jul 19, 2010 12:26 pm » Post: #11 » Download Post
Slightly off subject, but not....
91 Octane gas is way to low, surely that would cause detonation and eventually a terminal engine illness...?
My bike is not standard but also not greatly modified and I was getting mild detonation from 95 Octane and now only use 98 Octane.
So, although I haven't solved your problem I hope I can prevent a possible future one.
If I'm wrong let the slaughter commence.....
Stop sniffing my ring
MC28SP
KLX110 hotrod
CAG Minimoto
1997 WRX
21 Speed Bike
162 Smurfs
caffeinejoe90
Mon Jul 19, 2010 12:48 pm » Post: #12 » Download Post
A couple of things to try,
Flick the kill switch on and off ten times or better yet pop it off and clean the internals with some contact cleaner
Do the same with the ignition - on and off I mean
Check all electrical connectors are hooked up properly, clean them with contact cleaner and check that each wire is connected. Some people like to pull the connectors apart by grabbing the wires and it only takes one to recede back into the connector block to break a vital connection.
Unscrew your spark plug caps from the wire that connects them to the coils. Clean them with contact cleaner and also check they fit nice and tight onto the spark plugs. Clip 3-4mm off the wire and screw them back on.
Spark - remove a plug check for spark.
Gas - clean carb, set float height, high octane pump gas
Air filter - nice and clean
Rule #1 FULL CHOKE - NO THROTTLE
If you play with the throttle whilst trying to start a reluctant bike you will just flood it and unless you leave it for at least a half hour you are wasting your time, energy and winding yourself up for nothing!
If the bike starts and then stops a few times or starts on just one cylinder this is normal for a bike that has been sitting, if it wants to idle after this then great but still don't **** with it!
Leave it to warm up then give it a slow gentle rev.
People just can't resist that throttle, it is like a brake lever when your wheel is out, a dick magnet!
Seen it as million times
MC28SP
KLX110 hotrod
CAG Minimoto
1997 WRX
21 Speed Bike
162 Smurfs
atolldevil
Tue Jul 20, 2010 6:18 am » Post: #13 » Download Post
In my area 91octane is the highest i can buy from a gas station.
Don't know where i can get higher octane in my area.
Is there anything i can add to increase the octane?
caffeinejoe90 thanks for your advice.
I will try it on Thursday.
caffeinejoe90
Tue Jul 20, 2010 11:00 am » Post: #14 » Download Post
No worries - your local auto shop (car or bike) should sell 'octane booster' which will up the rating.
I would avoid the mc21 flywheel upgrade if you can't easily get higher octane juice as advancing the ignition will only increase chances of detonation.
Good luck!
Perhaps Obama needs to invade another oil producing nation so you can get some decent gas lol Wink
MC28SP
KLX110 hotrod
CAG Minimoto
1997 WRX
21 Speed Bike
162 Smurfs
atolldevil
Tue Jul 20, 2010 4:50 pm » Post: #15 » Download Post
I have another MC21.
It sit in my garage for half year like my MC28.
When i kick start the bike, it starts on just bottom cylinder.
The top cylinder is like something choke up, like not firing correctly.
First i thought it may be the spark plugs, so I replace a new ones.
Then i start it again, it still the same problem occurred.
Is the top end need to be replace, or the card need to be clean?
It is running pre-mix.
thanks
