MC16 trouble
Scott Carpenter
MC16 trouble
Tue Oct 05, 2010 5:45 pm » Post: #1 » Download Post
Does anyone have any idea why my MC16 goes through spark plugs in the front cylinder? Sometimes a new plug will only last 15 seconds! If the CDI was bad, it wouldn't go at all...switching them around is no help, either. Thanks in advance!
dunkenb
1989 Honda NSR250 MC18
Wed Oct 06, 2010 9:03 am » Post: #2 » Download Post
sounds like the carbs need a clean? check the float heights and make sure the float valves are sealing properly????
watfordhorn
1995 Honda NSR250 MC28
Wed Oct 06, 2010 9:44 am » Post: #3 » Download Post
Have you also checked connections to coils are all clean and your oil pump setting?
toneless
Wed Oct 06, 2010 10:52 am » Post: #4 » Download Post
It sounds like a flooded cylinder.
Turn the crank a few times with the spark plug removed and then try again.
You might also want to check that the RH pilot jet is still screwed where it is supposed to be.
Try a new spark plug, too.
If the above fails, I believe it's time to check for primary compression problems.
2t-racelab.com
Scott Carpenter
Wed Oct 06, 2010 3:01 pm » Post: #5 » Download Post
I have been over the ignition system, checked all connections for dirt and corrosion, all seems good. Eliminating that, I'm left with carburetor setup...I will check the float height, but I will have to find out what it's supposed to be. I don't believe it's flooding, the plug is dry when removed; a new plug fixes it temporarily. I can't hold my fingertip in the plug hole when the motor is kicked over, it blows my hand away easily so compression is not an issue. Thanks again, I'll let you know how it goes.
Wed Oct 06, 2010 3:22 pm » Post: #6 » Download Post
Technical Resources.
jimmy13
1990 Honda MC21 F3
Thu Oct 07, 2010 8:36 am » Post: #7 » Download Post
Actually Scott thats not true. I had an MC16 that ate plugs like they were going out of fashion it also developed a miss-fire on the bottom cylinder. The MC16 actually has 2 x CDI, try swapping these over and see if the problem moves with them in my case it did.
I have documented my experience in the post below
http://nsr250.net/forums/viewtopic.php?t=6434&highlight=
"............should have bought a Honda"
