MC28 HRC parts for beginner
mighty max
Thu Nov 11, 2010 9:49 pm » Post: #1 » Download Post
Hi everyone, im trying rebuild my MC28 into race machine. What should i buy for race part or upgrade? Need your kindly advised.
For start or my knowledge, i must need HRC stuff. So far i acquired:
1. HRC CDI & card P30(now under repaired by tech Guru Mr Moriwaki Man)
2. HRC stuffer,HRC valve reed,(Fixed)
3. HRC rear brake hose reservoir(Fixed)
4. HRC Jet kits(Fixed)but need needle B & C
5. HRC Y link pipe(fixed)
6. Airbox( Which type:open or close type)
7. HRC used exhaust but no rear can
Anything else i miss? Please help me to list down....
Tks Everyone..
Hope this topic will give the new beginner the basic reference for rebuilding for race bike..
cgallant
2001 Honda RS250
Thu Nov 11, 2010 10:17 pm » Post: #2 » Download Post
Who the hell ruined a perfectly good MC28 by putting an Aprilia RS seat on it!
Thu Nov 11, 2010 11:00 pm » Post: #3 » Download Post
You need some pipes, they are the biggest restriction on the MC28.
mighty max
Fri Nov 12, 2010 12:27 pm » Post: #4 » Download Post
cgallant wrote:Who the hell ruined a perfectly good MC28 by putting an Aprilia RS seat on it!
Sorry, i just bought this bike in this condition..I have OEM MC28 seat..Once i get the OEM or Tyga Fairing, then i fixed it...
Currently i just have HRC CDI now under repaired, HRC reed valve & stuffer & Brand new MC28 CDI with 2 cards..
Fri Nov 12, 2010 4:04 pm » Post: #5 » Download Post
As Fontyyy says, race pipes should be high on your list.
They all perform similarly really, so not much to choose between any of them. Get what you can on your budget. If you race then cheaper mild steel is likely a better choice in case you have the odd tumble. If you can pick up some stainless pipes on the cheap though, it doesn't matter! Smile
Best place to get a jet kit is either on here (keep an out on Classifieds) or Yahoo! Japan. Again, Moriwaki-man is probably your best bet. A jet kit will (should) come with X and Y pieces, adjustable needles, power jet blanks, slow jets, and a range of main jets.
Fri Nov 12, 2010 6:30 pm » Post: #6 » Download Post
Once you get your PGM and harness sorted out I'd get pipes and the jet kit.
It's then worth doing the front head mod and running the HRC air box.
A lightened flywheel help with pickup and doesn't cost much.
Run a non O ring chain.
mighty max
Sat Nov 13, 2010 6:04 am » Post: #7 » Download Post
StephenRC45 wrote:Once you get your PGM and harness sorted out I'd get pipes and the jet kit.
Tks for the advised but anyone doin lightened flywheel?
I want to keep the headlight as i will ride to the track....
Sat Nov 13, 2010 1:35 pm » Post: #8 » Download Post
In your part of the world, you may find TYGA will modify yours for you. Worth an e-mail to ask them. EMS within Asia is cheap, fast, and trackable, so you wouldn't be off the road too long.
mighty max
Sun Nov 14, 2010 12:06 pm » Post: #9 » Download Post
YUp, did email to MAtt & he said it is not eazy to find the jet kits.
Luckily i managed to asked around & managed to find a person who said that he have complete set of HRC,..well tomorrow goin down to see it...
mighty max
Mon Nov 15, 2010 2:25 pm » Post: #10 » Download Post
Ok, managed to get a new set HRC jet kits...
I only have A needles, anyone have B & C?
