Hi!
I want to get rid my old rear shock it is ''R'' speq and i have an mc21.
What choises do i have except the sp speq ones?
I mean is there any other that fits? dont want to give a fortune for some new ones...
Dimension wise the shock is a bit longer and I think the spring rate is a bit higher. The reservoir hose fitting coming off the shock body fouls against the frame bracing.
F3 the length C = 290mm the bottom shock mount is the same as nsr's but the top mount needs about 2mm removing from the width. I just took one out of my mc18 and replaced it with the standard one. Found it too stiff, couldnt get any static sag! Was going to put the nsr spring in the cbr body, but no bike shops where i live in the sticks had a proper spring compressor! _________________ it wouldn't be fun if it was easy!
Thanks! that means that the f3 youve got doesnt fit to the mc21/28 due to short length...
I believe the cbr 900rr is the best bet cause it has same lenght (at ohlins catalogue).
unfortunately the ohlins catalogue doesnt have any specs for the f3-f4 cbr's so we must find by asking...
