top end rebiuld
fovu
top end rebiuld
Wed Mar 09, 2011 10:44 am » Post: #1 » Download Post
hi
well it appears my new nsr is is need of a top end rebiuld as i can see some scratches on the piston and rings when looking up the exhaust port .so i really need some advise on how to go about it.my first question is can i remove the cylinders without removing the whole engine from the frame as you can on other bikes?what do i need to know about removing the power valves?do i just undo the cables or is there more to it?
i really would appreciate any advise you can give me as i would really like to get this thing on the road and enjoy the bike,just hope the cylinders are ok.
Harryredchow
Wed Mar 09, 2011 11:12 am » Post: #2 » Download Post
See here.
http://www.dreamgate.ne.jp/NSR/technical/mc28topend_rebuild.html
fovu
Wed Mar 09, 2011 11:33 am » Post: #3 » Download Post
thanks for the link,any other tips appreciated
NSR-LOVER
Wed Mar 09, 2011 11:55 am » Post: #4 » Download Post
http://www.nsr-world.com/workshop/rebuild/
nsrdownunder
1993 Honda nsr 250 mc21 sp
Wed Mar 09, 2011 4:42 pm » Post: #5 » Download Post
Hi Mate
It is a easy job to do . I don`t rely on standard piston sizes you are best to mesure the bore and send the size of to tyga to get the right pistons .
Vhargon
Thu Mar 10, 2011 9:50 am » Post: #6 » Download Post
yip, real easy. I just did my first top end rebuild, used the info from the main site. nsr-lover posted link.
You can leave engine in frame and you can get everything you need from tyga.
Do you want to remove/replace the valves or just disconnect them?
fovu
Thu Mar 10, 2011 10:01 am » Post: #7 » Download Post
hi
thanks for the replys,well i have got the the front cylinder off,the cylinder is in good shape but the piston has some scoring on the exhaust side.
i have only disconected the power valves,hopefully i can reconnect them without the need to adjust.
goin to order the parts from tyga,i have a c barrel but will measure it and get the right size pistons.
i was always going to do a top end rebiuld but wanted to actually ride it for a bit first,oh well at least i know it has been done and ready to go.
may even get new exhausts as it still has the originals then do the wire splice
bandit_7
Thu Mar 10, 2011 10:24 am » Post: #8 » Download Post
While you are at it you may as well do the bottom end too.
You mentioned 1 cylinder running cold. I didn't read the whole thread cause I'm lazy, but I have had that problem with 2 different engines.
Both times it was the crank seals failing. I checked everything else first only to find the problem deep inside.
You also have some damage to the cylinder and piston. Same as me except I discovered this at 180 kph.
I hope I'm wrong but worth checking.
Bandit_7
bandit_7
Thu Mar 10, 2011 10:29 am » Post: #9 » Download Post
Oops!!!
Just read the other post. Embarassed Embarassed Embarassed
fovu
Thu Mar 10, 2011 11:00 am » Post: #10 » Download Post
yep had a blocked slow jet,that cylinder idled properly and got up to temp after i unblocked it,has been a bit of a learning curve since i got the bike a week ago,i want to go for a ride Mad
