NSR250 SE MC21 Will not idle
mrmike
Sat Jul 23, 2011 7:53 am » Post: #1 » Download Post
Hi guys,
Im new to the forum, im from Sydney Australia, and have just purchased a 1992 MC21 SE. i bought it in a non running state.
I replaced the plugs, It started but revved its head off and had no throttle control whatsoever. i then realised the idle adjustment was all the way in, holding the slides about a quater open. I backed this all the way off and now the bike starts and runs great sounds really crisp.
Now the bike will not idle at all. and i am running out of ideas. i pulled the carbs out and took the bowl off. it all looked ok.
Any help would be greatly appreciated
Regards,
Mick
nsrdownunder
1993 Honda nsr 250 mc21 sp
Sat Jul 23, 2011 8:34 am » Post: #2 » Download Post
Hi Mate
Welcome to the forum and nsr`s
At what rpm can you get it to idle ?
I would clean out the carbs to start with . Check for air leaks
Also check the air screw adjustment .
If it runs good other than idle is probably a carb prob .
If that dosn`t work you should pressure test the crank as crank seals can leak .
Good luck
lam.666
Mon Jul 25, 2011 11:55 pm » Post: #3 » Download Post
try cleaning the pickups
NSR-lizard
Tue Jul 26, 2011 5:50 am » Post: #4 » Download Post
lam.666 wrote:try cleaning the pickups
Lost me! Care to expand on that?
Vampire?
anonymous.shyster
Tue Jul 26, 2011 9:22 am » Post: #5 » Download Post
1+ on what nsrdownunder said.
Check air screw adjustment (that's easy - it's that little thumb screw, usually sticks out near the choke).
Next, if it doesn't work - pull your carb off and clean the jets out (particularly the idle jet also called the pilot jet). Start it, warm it up and adjust your air screws with the airbox off (so you can get at them). Screw them equally in/out. Should be about 1.5 turns out.
nsrdownunder
Tue Jul 26, 2011 11:09 am » Post: #6 » Download Post
The pickup`s are the two black things just around the flywheel so what NSR lizard is saying is clean them up and clean the lumps that are on the flywheel . The pickups use them for the ignition timing
Look here : http://www.nsr-world.com/tuning/250-tuning/ignition/ at the top of the page the pickups are what the bolts number 9 hold on
Harryredchow
Tue Jul 26, 2011 12:16 pm » Post: #7 » Download Post
The pickups are magnetic units. I am not sure how cleaning will make any difference, unless they are caked in goo!
mrmike
Mon Aug 01, 2011 12:41 am » Post: #8 » Download Post
Thanks guys i will pull the carbs off and clean them up.
I just bought a bottle that i can put some clean fuel in and run a hose to the carbs so i can run the bike with the tank off. I will report back with the results, i'm really hoping its not a crank seal
