Wanted: PGM4 Meter Display
This topic is locked: you cannot edit posts or make replies.   printer-friendly view
diviCe
Mon Aug 01, 2011 10:11 pm » Post: #1 » Download Post
Hi Guys,
Does anyone have a spare PGM4 meter display they would like to part?
Please PM me.
It's Good to be Bad!
joeking78
Tue Aug 02, 2011 6:08 am » Post: #2 » Download Post
I've got a spare somewhere. Will have a look when I get home and let you know.
What's up with yours? If it's faded there is a way to fix it...
mighty max
Tue Aug 02, 2011 9:37 am » Post: #3 » Download Post
Mine is faded.. So to repair it bro?
diviCe
Tue Aug 02, 2011 1:44 pm » Post: #4 » Download Post
Mines cracked, all around.
I have a carbon fiber cover so fading won't be an issue.
joeking78
Wed Aug 03, 2011 7:47 am » Post: #5 » Download Post
mighty max wrote:Mine is faded.. So to repair it bro?
Disassemble the clocks and remove the digital display. You will have to completely remove it so you just have the actual digital display in your hand...then either put it on a radiator or under a hair dryer for a few minutes, let it cool and repeat until the last cooling part the dark/fading has disappeared. Worked a treat on two LCD's I had.
joeking78
Wed Aug 03, 2011 7:48 am » Post: #6 » Download Post
diviCe wrote:Mines cracked, all around.
Sorry, I thought you were talking abou the LCD, not the surround. I may have a spare knocking around, will let you know.
Wed Aug 03, 2011 10:34 am » Post: #7 » Download Post
This is NOT the place for discussion. This should be done via PM.
Locked.
