first start up hrc card
paul
Fri Aug 12, 2011 7:07 am » Post: #1 » Download Post
hi guys
i have got a second dash with matching hrc (30) card for my 28
when i pluged it in, I went to set the valves by unplugging the tps and nothing
they didnt open
I was under the impression that the loom splice was needed to get the lights etc to work with the hrc card, do i also need to splice the loom to get the valves to open with the hrc card
or is my spare PGM knackered?
thanks
paul
paul
Fri Aug 12, 2011 10:23 am » Post: #2 » Download Post
ok
couldnt wait
spliced the loom and it still doesnt go, another pgm for the scrap pile
diviCe
Fri Aug 12, 2011 10:29 am » Post: #3 » Download Post
Don't throw it away, Keep it for spares or repairs... Else I'd take it off your hands =D
It's Good to be Bad!
mighty max
Fri Aug 12, 2011 10:30 am » Post: #4 » Download Post
Splice the wire. If the valve not working, get a new valve. This is what happen to me
paul
Fri Aug 12, 2011 10:39 am » Post: #5 » Download Post
bit gutted right now but need a new plan
half way through this build so next best thing is going to be a mc21 flywheel or offset woodruff key
does anyone know how much offset is equivalent to putting the 21 flywheel on the 28?
mixalisen
Fri Aug 12, 2011 3:31 pm » Post: #6 » Download Post
Paul hi,
if the power valves don't working and the cause is the PGM-IV then there is no problem... Contact this member "2T Institute" and send it to him in order to fix it for you... Also check here http://www.twostrokeracelab.com/ Nick his name... Great guy and very helpful...
Michael
Dexter
Fri Aug 12, 2011 6:43 pm » Post: #7 » Download Post
I think you mean "2TRacelab" Michael...
mixalisen
Fri Aug 12, 2011 7:42 pm » Post: #8 » Download Post
Yeap...!! This is what i ment Dexter... Thanks...!
toneless
Sun Aug 14, 2011 8:24 am » Post: #9 » Download Post
I believe that the Mc21 flywheel has about 2 degrees more static advance.
You can swap to a Mc21 flywheel, buy a Tyga pre-made woodruff key or machine off your own woodruff key in 0.1mm increments until you find the desirable performance.
Please, keep in mind that more ignition advance radically leans the fuel mixture. Mc28 bikes are way rich to start but don't count on that and do a spark plug chop.
2t-racelab.com
paul
Mon Aug 15, 2011 6:50 am » Post: #10 » Download Post
legend!!
