G'day folks,
I'm in the process of giving some loving to my old girl, and decided to replace all the hoses and lines. Most are easy enough but my main concern is the oil feed lines, mine look old and wearing through where the wire connector is at the pump.
Where can I find replacements - as there shaped?
Or can I use standard line, does it have to be a special type? I was thinking of using a clear vacuum line and try and find some fresh connectors?
Anyone replaced these? I assume they are a 4mm vacuum line size same as the rest of the bike?
Lee
