When I turn on the key, neutral and side stand light bulb turn on normally and when I switch the run on the oil light bulb doesn't turn on.
I Know that in other NSR MC21's SP this oil bulb turns on until the engine is turned on and then it switches off.
I have checked that the bulb is good because when my oil level is low the bulb switches on normally so the problem seems to be only the initial test!
Not sure if there the same, but my R5K only lights up the first time I turn the switch, if I switch back without starting it up and try again it won't light up. I read some where this is normal.
