Hi guys, there are lots of references made in various posts about rebuilding or re-gassing the SE/SP shock. I have done quit a few rgv250 shocks in the past and they are easy enough to do, however looking at the NSR shock i will have to weld a schrader valve to the back cap of the reservoir cylinder? Also i cant see how it works? the rgv showa shock has a bladder which is pushed into the reservoir and once locked in place is filled with nitrogen to displace the oil. The NSR one seems to be the reverse with the bladder in backwards placed under pressure by the nitrogen surrounding it? is this how it works? i have replaced the oil and removed the air but is the bladder normally full of nitrogen or oil? I cant see how it would work???
I wonder if someone has had it apart and assembled it incorrectly?
This is all vague as hell, but I had a shock recently rebuilt and all they did was put a schraeder valve on the reservoir. I don't know what they did because it was done by a so called "guru".
yeah, i know i have to add a schrader valve but this will put pressure in behind the bladder and not in it, i guess the bladder is filled with shock oil instead of nitrogen and the nitrogen surrounds the bladder?
thanks matt, just making sure im doing the right thing. how the hell do you get the oil in the bladder and bleed the air out those two little holes? I will give it a crack later on.
fair call Matt, I do all the work on my bikes myself as i like to understand how things work. I got sick of taking things to bike shops and have them coming back with vice marks and hammer hits all over them. Im a bit of a perfectionist when it comes to things mechanical. The more i try the more i learn, the more i learn the more i understand.
I got a few ideas how to get the air out of the bladder, i will grab some nitrogen out my work van and we should be good!
One trick is to use the bladder as a sort of squeezy.........put oil in the shock body, give the bladder a squeeze and let it suck the oil in. After that, careful positioning of high points and you can bleed all the air out with a bit of a squeeze and suck here.....and a tap with a mallet there.
One thing that may cause some shock builders an issue is that air can sometimes lurk in the valve under the shim stack. Just pushing the valve through the oil slowly doesn't release it as the shims never open and the oil goes through the bypass or low speed orifice. A strategically aimed sharp crack or two with a mallet opens the shims enough to release the air.
All done, didn't take too long, the only problem i struck is that i didn't notice the split ring that enables the two bottom plates to separate for spring removal and i ended up taking the lower eye/adjuster off to remove the spring. when i screwed it back on i messed up the adjustment screw so it didn't work. i had to remove it and re-bleed. I noticed the split ring when i went to refit it. there is no air in it now and i filled it with 150psi of nitrogen. it seems real soft but i need to wind the preload back into it as i backed the rings right off. will try that tomorrow night.
With it full if gas, fully compress it and allow it to extend. You can fiddle with the rebound adjuster at this point to check that it's functioning properly.
Also, if it doesn't fully extend then there's air in there. Or if when you fully compress it it quickly moves a couple of mm before the rebound damper takes effect, same problem.
Anyway, good on ya for doing it.
FYI, the shimming on the stock shock and the F3 shimming are very different. Early F3 shocks also have a very different valve. Later F3 shocks use the same valve as an NSR, which is same as CBR250RR, VFR400, RVF400 and plenty more I'm sure. In fact, they all mostly use bits from the same parts bins.
I've not tried a double shim stack on the rear, but it works on the forks. Gives a real plush ride around the town when you're cruising, but then stiffens up at full tilt.
kiwisteve74 wrote: The more i try the more i learn, the more i learn the more i understand.
Then there is realisation. That you can go to work and earn more than it costs in the same amount of time it took you to do the job . I'm surprised nobody uses thes shocks which are bloody good and extremely well priced. I get them from the UK and for much cheaper than any local suspension places for the same features.
Once you know the insides of a shock it's pretty easy to then be able to shim and damp it to compete with most aftermarket stuff. Ok so a steel body's not as trick as aluminium but it's always good to be able to do it yourself. And in my book the knowledge gained by hands on experience is worth it
Matt@TYGA wrote:Once you know the insides of a shock it's pretty easy to then be able to shim and damp it to compete with most aftermarket stuff. Ok so a steel body's not as trick as aluminium but it's always good to be able to do it yourself. And in my book the knowledge gained by hands on experience is worth it
Sometimes it is, sometimes it isn't.I spent lots of time and lots of $$ getting a 'cheap' set of Swedish $hitter Shocks to work on my vmx bike. Bit the bullet and bought a set of YSS shocks have not touched them since I bolted them on(except for setting the rebound) I reckon I spent less on buying the YSS than I did, shims, seal heads springs etc etc. Not to say that the knowledge isn't worthwhile I just don't have the time to play with suspension gizzards.
Yes it's a High/low speed comp Nitron <$900 AUD landed, colour grows on you especialy after you go for a ride.
