oil light
kaloo1812
oil light
Mon Oct 10, 2011 8:53 am » Post: #1 » Download Post
hi i have a nsr 250 mc 16 , been giving me endless problems , thought maybe you guys could please help me out. Firstly when i start the bike the oil light does not go off and it does not smoke as it used to , secondly when i start it , it idles for a while then cuts off sometimes but never starts again, and now if i turn the throttle while idling it cuts off, please help all advise is welcome.
joeking78
Re: oil light
Mon Oct 10, 2011 11:49 am » Post: #2 » Download Post
kaloo1812 wrote:hi i have a nsr 250 mc 16 , been giving me endless problems , thought maybe you guys could please help me out. Firstly when i start the bike the oil light does not go off and it does not smoke as it used to , secondly when i start it , it idles for a while then cuts off sometimes but never starts again, and now if i turn the throttle while idling it cuts off, please help all advise is welcome.
Have you filled it up with oil? Wink
Is the fuel tap on?
1996 MC28SE (Honda Flash), 24,000KM - Drilled airbox, HARC Pro pipes, TYGA Hi-flo reeds, special manifolds, Ohlins rear shock & steering damper - SOLD
1993 MC21SP (Winner's One), 10,000KM - Drilled airbox, wire splice - STOLEN!!!
1990 MC21SP (Cabin), 20,000KM - NC30 forks, discs, calipers - EN ROUTE...
kaloo1812
Mon Oct 10, 2011 12:03 pm » Post: #3 » Download Post
yes fill with oil and the tap is open.
kaloo1812
Wed Oct 12, 2011 11:28 am » Post: #4 » Download Post
changed a fuel filter now it starts first kick, but oil light is not going off and there is enough oil in the bottle? i checked the thingy when you turn the throtel it turns for the the oil pump, but still not smoking , any idea what problems i may be experiencing?
cheers
kaloo
dunkenb
1989 Honda NSR250 MC18
Thu Oct 13, 2011 3:10 pm » Post: #5 » Download Post
Have you pulled the oil feed pipes off by the carb to see if oils coming through. Also try bleeding the oil pump. Theres alittle screw on the pump body you undo to let air out. Cool
