POWER
I want to keep the oil injector, don't want to change the carb.s except for slow and main jets, want an airbox. I am after reliability and not having to rejet much, but it would be nice to get a little more power. 59-60RWHP would be just about right, and it should be achievable within the constraints of reliability I stated above.
JETTING
I dynoed at two main jet settings, 155 and 160. I rode it at 165 (and seized it at 145) and I think it didn't feel so good. So is it likely that the 160 main jet is going to be safe on the long back straight at Motegi? Also what kind of temperature swing is it going to take before I need to rejet?
SETUP:
MC21
HRC black box PGM deriestrictor
Dry air filter (Daytona)
Tyga high-flo reed set
Carbs stock with 40 SJ and 160 MJs
The bottles under the carbs have been romved and holes blocked off
JHA chambers and endcans; it all looks pretty old, and there is a dent in one chamber at the widest point, and the other one has a slight bend at the narrowest point where it is reinforced and goes from wide to narrow. Endcans look old-ish.
Airbox has had the back chopped off it and the divider inside removed
The front cylinder has the HRC head conversion with 0.6mm gasket
The front cylinder has had the outside of the exhaust ports widened.
Rear cylinder is an A, front is a B, both have new pistons and rings.
Oil injector is adjusted to maximum.
http://invigiator.com/crap/dyno_155_160.jpg
http://invigiator.com/crap/dyno_155.gif
http://invigiator.com/crap/dyno_160.gif
Image properties edited by Admin
MC28 SE -sold-
