A good friend has give me two Aprilia RSW 250 coils, from a GP bike, in perfect shape. I was thinking to buy a pair of RS coils in the marketplace, but i wonder if i can use these ones.
Coils are Denso, and have only the first part of the reference number on it, 129700- but seems that all Denso coils starts with that number. I have measured them, and the resistance is 8.8 ohm.
Another issue, is that these coils have only one wire connector, the ground is taken from the coil mount itself.
I believe the earths on the primary coil run back to the PGM on a stock setup. That could be your only issue in running these. A few tests with the multimeter should show if the earths are required to go all the way back to the PGM. _________________ Cheers,
Dave.
