MC21 After mafket shocks
greggo
Tue Jan 10, 2012 2:56 am » Post: #1 » Download Post
So my SE shock can't be rebuilt its a bin job. The standard Rate shock isn't worth it so it appears I'm facing an aftermarket.
Locally wilbers is the best value at about 1k aud.
Any other brands I should consider of similar quality? Anyone know of any deals or had a particularly good experience with one brand?
Dmitry
Tue Jan 10, 2012 3:24 am » Post: #2 » Download Post
Ohlins can be had for about $800 USD.
http://www.hardracing.com/Ohlins.htm
nxrsr20
Tue Jan 10, 2012 3:58 am » Post: #3 » Download Post
Before you bin it, can I salvage it for parts? It can be regassed and resprung, but I haven't seen anything about revalving it.
greggo
Tue Jan 10, 2012 4:07 am » Post: #4 » Download Post
If you're after the SE shock, i'm not sure there are any parts to salvage!
nxrsr20
Tue Jan 10, 2012 4:18 am » Post: #5 » Download Post
Can you hang onto it anyway? I wouldn't mind doing an autopsy on one just to see what is in it.
Canuck13
Tue Jan 10, 2012 1:47 pm » Post: #6 » Download Post
Fwiw I have a Wilber's on my 21. Works fine. Once I get my calipers sorted I will see how it goes with the maxton rebuilt forks Smile
Only issue with Olin's is they are apparently a discontinued line for the nsr and you need to track down either nos or a used one.
Dmitry
Tue Jan 10, 2012 9:23 pm » Post: #7 » Download Post
I spoke with Ohlins USA couple days ago and they can get me one, takes couple weeks from Sweden. HO206 fits MC21 and 28 according to them.
Canuck13
Tue Jan 10, 2012 10:34 pm » Post: #8 » Download Post
Fair enough, just when I was looking a couple of years back while it was listed, i was told they were discontinued when I dug into getting one from the Aussie importer. Maybe they have decided to build em again.
scottvor
    Send private message View user's profile Send e-mail AIM Address
Wed Jan 11, 2012 11:17 pm » Post: #9 » Download Post
SE/SP shocks can be rebuilt and revalved. I was running a RaceTech gold valve on mine. I believe main shaft seal is from Fireblade (CBR-900RR).
Scott
greggo
Thu Jan 12, 2012 12:03 am » Post: #10 » Download Post
So I have committed to the wilbers (1100 AUD) . Both Maxton and ohlins, while I could get them a few hundred cheaper at around 800 AUD + postage, I think the extra dollars are warranted for having it built for me and supported locally. If they fk up the damping range they should rectify for gratis.
As ride height wasn't available we went with making the shock 5mm longer. With careful set up and attention to geometry we should get an excellent balance of weight distribution and ground clearance.
My SE shock was too rusty and nasty to be rebuilt.
