This pic shows the other side, which has a different shaped hub with a square finish and two small cutouts, which I am guessing are from a bike with speedo cable off the front wheel?
Possibly an early RS250 nf5, do the disc mount holes go right through, or are they threaded? _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
Just measured 21 magtek and RS250 magtek, and both are bigger across hub, i got a sneaky feeling it may have been machined down for some other fitment, or like i said earlier, possibly a real early RS wheel, 85-86-87, having said that, RS wheeels have threaded disc mounts, but could have been drilled out, but inclined to think it has been altered. Do you know what bike it was in previous? _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
Ripped my MC21 SP front wheel off yesterday to compare and took some measurements and it now appears that it has been machined, the Magteks hubs inner bearing housings have heaps of meat in them, enough to machine the housings 20mm closer together.
Someone has commented that it looks very similar to a TZR125 hub?
