Can anybody tell me what this actually is, and/or does and who makes it?
Is it just an expensive way to do the wire splice on a PGM-II?
Or does it actually change the ignition curve and/or air-jet solenoid opening times and/or powervalve control ??
I am thinking of buying it but cannot get my hands on it to pull it apart. Just curious more than anything. _________________ [color=#808080][size=9]Yes,.. I too know how to waste Time and Money,...
It's just a wire splice in a box. Looks to be the HRC unit.
The wire splice does change the ignition timing and power valve timing so yes that box does do those things too. _________________ If I have to take the carbs off once more...
They usually come with a repousse HRC logo on them and not a sticker.
I spent a couple hours on one and couldn't trace anything more than that it lifts the Orange/ Blue wire from ground and shorts it to +12V DC. _________________ 2t-racelab.com
That is an HRC unit. I think later on they stopped having the HRC embossed on them as I have two CBR400 NC23 HRC units and they are identical apart from one has HRC embossed on it and the other a sticker just like that but both have the same HRC middle parts code stamped on the back
