Oil pump connector part number
Roman250
Fri Mar 09, 2012 9:44 am » Post: #1 » Download Post
Traced a small leak to this cracking connector for the 2t oil, but I can't find the part number in the parts manual. Any idea?
http://imageshack.us/photo/my-images/85/photohsp.jpg/
Mon Mar 12, 2012 11:17 am » Post: #2 » Download Post
Which model are you asking about?
Is that from the oil tank to pump or from the pump to the carbs?
Chester362
Mon Mar 12, 2012 9:18 pm » Post: #3 » Download Post
I assume it's the white plastic T-piece you're talking about.
Part no. 11 on page I 2. Rear Cowl/Glove Box.
55105-KV3-830 Joint Oil tube.
You could do a temporary repair with epoxy resin or some kind of fibre glass tape and super glue kit. I've found that plastex/plastech works well on this kind of thing.
Roman250
Tue Mar 13, 2012 3:03 am » Post: #4 » Download Post
Chester362 wrote:I assume it's the white plastic T-piece you're talking about.
That's the one. Thank you.
Roman250
Wed Mar 14, 2012 3:35 am » Post: #5 » Download Post
Anything I should do before or bleeding to do after replacement??
