MC18 & MC21 flywheel differences
2Smoke
1987 Honda NSR250 MC16
Wed Apr 25, 2012 6:35 pm » Post: #1 » Download Post
Anyone know what the differences are between the mc18 r5k and mc21 flywheels are?
Thanks
Paul
Wed Apr 25, 2012 6:50 pm » Post: #2 » Download Post
Ignition timing, but I can't recall how much.
2Smoke
Wed Apr 25, 2012 6:55 pm » Post: #3 » Download Post
Thanks Stephen,
2 Degrees by any chance? Been doing a bit of digging, seems the '18 one is retarded compared to the '21 item, but the 28 item is retarded compared to the '21 so maybe a match for an '18?
Not racing until I've got a flywheel so may be a cheap summer!
Wed Apr 25, 2012 7:06 pm » Post: #4 » Download Post
Nothing is as retarded as much as a MC28!
The '18's was retarded more than a '21 but only by a little, the '28's is much further retarded.
2Smoke
Wed Apr 25, 2012 7:10 pm » Post: #5 » Download Post
Ok, maybe worth searching for a '21 on then!
Thanks for that!
Wed Apr 25, 2012 8:08 pm » Post: #6 » Download Post
StephenRC45 wrote:Nothing is as retarded as much as a MC28!.
Apart from the owners Very Happy
watfordhorn
1995 Honda NSR250 MC28
Wed Apr 25, 2012 9:16 pm » Post: #7 » Download Post
haha, and you own one yourself!!!!!
Wed Apr 25, 2012 9:26 pm » Post: #8 » Download Post
Nice to see you back Leigh! Laughing
Not seen you post for a while! You must have a bleeper go off, set for the keyword "MC28"?! Laughing
watfordhorn
Wed Apr 25, 2012 9:44 pm » Post: #9 » Download Post
It's set for mc28 along with any other keyword like "lemon", "retarded", "slow" etc etc.
I have been busy getting the new rs bodywork fitted and getting the retarded mc28's up and running Sad. I just bought another 28 sp rolling chasis so should have one of each 28 sp and a full on tyga bike soon.....I must deserve lots of abuse for that some have kept my head down.
Dont worry, I have been keeping a keen eye on what's going on though!!
Thu Apr 26, 2012 7:57 am » Post: #10 » Download Post
Exactly, What was i thinking buying a 28! Embarassed
Thu Apr 26, 2012 4:40 pm » Post: #11 » Download Post
bloody traitor paul Laughing
watfordhorn
Fri Apr 27, 2012 3:07 pm » Post: #12 » Download Post
silikesguiness wrote:bloody traitor paul Laughing
.....and he has just bought himself a four stroke!!!!
cangus
Mon Apr 30, 2012 1:29 pm » Post: #13 » Download Post
If using an MC18 wiring harness and MC18 coil in an MC21 motor, should the flywheel then be the MC21?
MC21R9N track
MC18R2J track
CBR954
CR250
Mon Apr 30, 2012 2:03 pm » Post: #14 » Download Post
The harness and coils make no difference; it's the ProGraM in the PGM that makes the difference. Smile
TuckerBag
Mon Apr 30, 2012 7:12 pm » Post: #15 » Download Post
Assuming there is a difference in the position of the pick-up triggers on the MC18 and MC21 flywheels (in relation to the crankshaft), then to keep the timing standard you have to run the MC18 flywheel with the corresponding MC18 PGM (be it PGM-I or PGM-II) and run the MC21 flywheel with the corresponding MC21 PGM (PGM-III)
But the whole point of this thread is to find out exactly what the difference is between the MC18 and MC21 flywheels in terms of the ignition timing triggers.
I would like to know, because, it may be possible to advance or retard the ignition simply by swapping flywheels.
This in combination with offset woodruff keys may make quite a few different offsets possible in terms of ignition timing.
So back to the original question,... does anyone know what pick-up trigger difference there is (in degrees) between MC18 (R5k / R6k) and MC21 flywheels?
