Scarborough Gold Cup 2009 John McGuiness narrowly beat us to 4th and if memory serves we were 9th home (2nd Honda) in the MotoGP support race run by the North Gloucester club at Silverstone. Rob Mawbey from Racing Lines Derby has also ridden the bike a couple of times including a win and top place finishes at Darley Moor. The bike has not been run since the end of last year when I tried it myself for a few laps at a track day.
From my notes, the crank has 720 miles, cylinders 410 miles, pistons/rings/little ends/pins 220 miles. I fitted two new standard cylinders when I bought the bike, there is a spare cylinder in the package that is currently being plated at Aptec. The bike is setup for Hiperflo 250 unleaded running VHM heads and inserts with Luyten pipes. We have always run the bike on safe jetting using the data logger and det counter and have had 100% reliability the few times the bike has been used. It is currently fitted with ex Ian Lougher reed splitters which seem to work well with the Luyten pipes. The bike was originally set up for Hiperflo on the dyno at FWD with assistance from Ian Emberton. Suspension was completely overhauled by Maxton prior to the Gold Cup and have very few miles since. The bike has HRC det counter, HRC logger, Battle factory rearsets, Samco hoses, upgraded Brembo calipers, low 1st/2nd gears installed, race pattern shift with quickshifter.
Bike with running kit / spares is £13,000 ovno, spares package is itemised and separately negotiable according to requirements.
Phone: +44 (0)7803 669862
Bike and running kit / spares
RS250 2007
Data logger
Detonation counter
Maxton front & rear suspension
Uprated brembo calipers
VHM heads with inserts for Hiperflo 250
Luyten pipes with titanium stingers, minor scuffs to one side
Race pattern shift with quickshifter
Samco coolant hoses
Fitted with 2 x low miles new std cyls
Ex-Lougher reed splitters with reed blocks / rubbers
New loom
Goodridge brake hoses
Low 1st, med 2nd gears
1 pair Marvic wheels slicks fitted to bike
1 pair Marvic wheels wets
Workshop manual
Spare cylinder unused since replate
Jet kit
Power jet cut-off plugs
Front sprockets 14,15,16,17
Rear sprockets 34,45,36,37,38x2,39
1 x drum Hiperflo 250
Spare used airbox intake
Spare repaired bodywork, fresh paint
Sundry used bodywork, needs paint
Good used loom
Good used clutch lever
Good used clutch plates and steels
Spare double bubble screen New
Spare carbon stingers, used
Spare coolant hoses and clips
Original front fork internals and springs - pre maxton
2 x rear springs
2 x reed blocks - no splitter, OE used
Spare subframe, slightly bent but usable
Original OE brake hoses front and rear
1 x used crank, reported as low miles
2 x det-counter plugs new
1 x spare VHM hiperflo head new
2 x unleaded hrc heads, good used
Battle factory right hand hanger new
Battle factory gear lever
OE left hand hanger used
Brembo brake lever used
OE brake lever used
2 x footrests used
OE heel plate used
Gearbox cover gasket new
Reed block gaskets used
Good used reeds and spare reed holders/screws
Good spare throttle cable
5 x 14132-NXA-003 reed block gaskets, new
Large number of new base gaskets
2 x 50807-NXA-000 upper fairing stays, new
2 x Carb jubilee clips used
8 or more inner cylinder head O-rings, unused
6 outer cylinder head O-rings, unused
5 x 19506-KS6-700 HRC jubilee clips, new
1 x gear shift link for use with quick shift, used
1 x gear shift link for use without quick shift, new
1 x 53173-376-000 clutch bracket clamp used
1 x 18332-KS6-000 exhaust retainer spring new
Spares package
New unpainted complete set Mendez bodywork kit
New airbox intake
Total loss ignition kit including rotor
Substantial gear kit with all possible ratios except a couple of 6th gear options.
New radiator in box
2 x new cylinders in box
1 x new crank in box
1 pair Marchesini wheels intermediates
2 x 13100-NX5-791 pistons new
2 x piston rings new
2 x 13111-KV3-000 gudgeon pins, new
2 x 91101-NX5-023 little end bearings new
2 x plug caps new
2 x PFCarbon Metallic brake pads front new
New Regina 520GPMV-120 chain
std hrc pipes low use
Subframe new
2 x original unused Brembo calipers, mint
2 x unleaded VHM inserts
1 x new HRC handlebar
1 x complete set new Battle factory rearsets
Clutch lever new
Curve bender
Quick action throttle
HRC power lead
New clutch lever bracket
New chainguard sharkfin
Carbon fibre airbox door new
2 x HRC grips new
2 x 65210-nx5-000 fairing mount tubes new
1 x 91001-NX5-003 main bearings new
1 x 91003-NX5-003 bearing new
5 x 22401-KA5-740 clutch springs new
1 x 91203-KK3-830 power valve seal
Good spare power jet solenoid
4 x 90447-KE1-00 copper washers new
2 x 18231-NX5-000 exhaust flange gaskets new
2 x 19229-NX5-003 water pump gaskets, new
2 x 19219-NX5-003 gasket, new
2 x 94301-06100 cylinder head dowels new
3 x 96211-06000 clutch ball bearings new
2 x 91302-HA5-003 outer cylinder head O-ring new
4 x 94050-08000 cylinder base nuts new
6 x 91205-PH8-005 power valve seal new
8 x head studs new
91271-MB0-013 seal new
2 x 16010-NX4-780 carb bowl rubber O-rings used
2 x 91024 GJ5-003 power valve bearings new
4 x good used base nuts
4 x 90135-HA7-770 studs new
1 x 53105-NF4-770 handlebar end plug new
1 x 91211-KA3-761 seal new
2 x 91201-965-000 seal new
1 x 90037-NX5-000 cylinder bleed screw new
1 x 50814-G?Z5-003 bearing new
1 x 91201-KM4-003 seal new
4 x power-valve spherical joints used
2 x power valve spherical joints new
Admin: Copied to the Classifieds to give better exposure. Advert will appear in RS Discussion and Classifieds.
