mc18 very little power on takeoff
nsrjb
Tue Jun 26, 2012 6:39 pm » Post: #1 » Download Post
my bike runs fine great pull through to redline in all gears.
but if i stop on an incline and try to take off the bike wants to die and cut out.
i have to keep nursing the clutch till i get a bit of speed up and its fine then.
my nsr 80 and 125 never had this problem.
i have cleaned the carbs and no difference compression is good.
powervalve is working 100%
bushman
Wed Jun 27, 2012 1:52 pm » Post: #2 » Download Post
Have a look at the spade connections to the coils,may need a clean and a squeeze.
Neal
Wed Jun 27, 2012 1:59 pm » Post: #3 » Download Post
When you blip the throttle do the revs drop slowly or quickly ?
If the pilot jet circuit is not clean and causing it to be lean the bottom end of the rev range will be weak as you describe .
