Pgm1?
2Smoke
1987 Honda NSR250 MC16
Pgm1?
Mon Sep 03, 2012 1:35 pm » Post: #1 » Download Post
The 'Jigsaw' that I picked up at the weekend is running a PGM1.
Is it worth swapping over to a PGM2? I have a spare one in my parts box, so would need to buy a loom to make it work, but I have no idea about the differences between the 1 & 2.
Alzazorq
Mon Sep 03, 2012 3:02 pm » Post: #2 » Download Post
Hey Paul,
Definitely go for the PGM2, have a look at the Model History on the left side of the page. There you will find more info. The PGM2 is much more advance than it's predecessor and the obvious, there's less boxes to worry about !
Mario
Mon Sep 03, 2012 5:12 pm » Post: #3 » Download Post
To do the full PGM-II update you will also want a PGM-II flywheel/pick ups. Though the PGM-I flywheel and pick ups can be used. You will also need a loom as you say and if I recall a second air solenoid.
Mon Sep 03, 2012 6:00 pm » Post: #4 » Download Post
And then you will need to modify the cases!
There's nothing inherently wrong with the PGM-I, plus it's unrestricted as stock. Just leave the Black/Blue wire disconnected for full RC operation!
The good thing about the PGM-I system is that if the RC Valves fail, you can replace the controller. It doesn't kill the PGM like on the II, III, and IV.
Alzazorq
Mon Sep 03, 2012 6:35 pm » Post: #5 » Download Post
Why do the cases need modifying Andy ?
2Smoke
Mon Sep 03, 2012 7:40 pm » Post: #6 » Download Post
Okay thanks guys, I'll see how it goes with the PGM1 on, it's only a wet bike anyway so no need for monster power Cool
Mon Sep 03, 2012 7:53 pm » Post: #7 » Download Post
Alzazorq wrote:Why do the cases need modifying Andy ?
I think Andy means if you're going to the trouble of fitting a PGM-II system you might as well modify the cases to make the best use of the ignition system.
Any flywheel will fit as long as its matched with the correct pick ups from the right model.
Or you could go the RS/F3 route...
2Smoke
Mon Sep 03, 2012 8:05 pm » Post: #8 » Download Post
I have the RS setup for the '16. Also got 2 sets of cases already modified, one mc18 and one mc16 f3.. hmmm Idea
Any luck with that airbox Steve?
Mon Sep 03, 2012 10:11 pm » Post: #9 » Download Post
Sorry, misjudged use of wording.
"And then you will want to modify the cases!" would've been a better choice. Sorry for any confusion.
As Steve allures to, the way the various "upgrades" of the MC18 R5/6K work, it can make use of additional machining within the cases. There is a noticeable "lump" in the 1989 mid-range over all the other models. This, combined with 1990~ modifications will create a strong motor, easily getting into the mid~high 60's hp range.
All things we can do via NSR-WORLD.COM Performance.
Kostas Dee
Tue Sep 04, 2012 9:09 am » Post: #10 » Download Post
Still there's nothing wrong with the PGM CDI,if you have all the right parts then do it but if you dont,leave it as it is.
